Wendy Bowen Wrote:
4.0 server. The hard drive that is going to be the mirror must not
be formatted or partitioned at all, it must be totally blank (as in
right out of the box). This doesn't seem right but that's how it
worked for me. Reading the directions from Microsoft led me to
believe that the second drive (the mirror) had to be formatted, but I
had the same problem that Wendy had!
---Original Message---
Message: 7
Date: Mon, 10 Sep 2001 09:59:39 -0400
Subject: Re: (OT) server harddrive
That's the way I did it. Unfortunately, I still received the
problem. I suppose that the second drive could be bad. I just
thought I'd pursue other ideas before I concluded a bad drive.
Wendy Bowen
Network Administrator
Schmald Tool & Die, Inc.
(810) 743-1600 ext.323
wpursche@...
> I just installed new hard drives on our server. They areI was also confused by this when I tried to set up Raid 1 on our NT
> both the exact same model, serial number, brand, and size.
> When I go in to disk administrator to mirror the drives it
> says that my partitions are not the same size on one hard
> drive as they are on the other.
Message: 7
Wendy Bowen
wpursche@...
----- Original Message -----
To: 'vantage@yahoogroups.com'
Sent: Monday, September 10, 2001 9:44 AM
Subject: RE: [Vantage] (OT) server harddrive
Leave the second drive as empty space. Select the primary drive and
the
empty space and then establish the mirror. Windows will set up the
second
partition for you.
Brian Boyes,
Systems Administrator,
Precision Resource Canada Ltd.
<http://www.precisionresource.com>
<mailto:brianb@...>
> -----Original Message-----
> drive as they are on the other. I know that I partitioned
> them correctly. When I use Server Magic to change the
> partition size on one of them it gives me an error and brings
> up disk administrator..
