[OT] Server Room Monitors
Went with a sensaphone and hooked it up today. Tested and it works
great. Oh how I cannot wait for that 2am call :)
--- In vantage@yahoogroups.com, Todd Caughey <caugheyt@...> wrote:
> I've used Sensaphone monitors for over 20 years at a number of
companies. Currently use a Sensaphone 800 and it does exactly what
you are looking for and a lot more. It also has input and
open/closed switch detection for a number of accessory devices such
as water detection, door open and other devices. I mainly use it
for power, temperature and noise level (incase an alarm is
sounding). I can call it form at home and it will detail all the
environmentals as well as allow me to listen to the room for 10
seconds. Not too hard to program once you get used to it and it is
not something I change often anyway.
> Check: http://www.sensaphone.com/sensaphone-800.html
> It was $564 through Zones.com and cheap insurance in event of A/C
failure over a weekend.
> -Todd
Behalf Of Michael McWilliams
> Sent: Monday, May 19, 2008 1:24 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] [OT] Server Room Monitors
> Any recommendation on server room monitors that will call or page
> for alerts of power failure or room temp?
Check out APC's version on their website. It might be costly though.
Sent: Monday, May 19, 2008 2:24 PM
I've used Sensaphone monitors for over 20 years at a number of companies. Currently use a Sensaphone 800 and it does exactly what you are looking for and a lot more. It also has input and open/closed switch detection for a number of accessory devices such as water detection, door open and other devices. I mainly use it for power, temperature and noise level (incase an alarm is sounding). I can call it form at home and it will detail all the environmentals as well as allow me to listen to the room for 10 seconds. Not too hard to program once you get used to it and it is not something I change often anyway.
It was $564 through Zones.com and cheap insurance in event of A/C failure over a weekend.
-Todd
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Michael McWilliams
Mike:
I have been using a RoomAlert 11E from AVtech. You can see them at roomalert.com. I am completely satisfied with it. Easy to setup, easy to use, monitors temp and humidity. I am not using it to monitor power (my UPS does this), however, I believe this can be done. Their tech support is good as well. This device can also do SNMP traps for lots of other things. When the temp in my server room goes above a set limit, this device pages the entire maintenance dept and myself, and also sends email alerts to all of us. It has a nice web based GUI as well.
Hope this helps,
Dale
>>> "Michael McWilliams" <mmcwilliams22@...> 5/19/2008 2:24 PM >>>
The information transmitted including any attachments is intended only for the exclusive use of the person(s) or entity to which it is addressed and may contain confidential and privileged material that may be subject to legal privilege. Any perusal, review, retransmission, dissemination, distribution, reproduction or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient without the sender's prior consent is unauthorized and strictly prohibited. If you have received this message in error, please notify the sender immediately and delete the message from your computer without making any copies. Any personal views and opinions expressed in this email message are the sender's own and do not necessarily represent the views and opinions of the Company. This footnote also confirms that this message has been swept for the presence of computer viruses but this does not guarantee that it is virus free.
Thanks for the input. Just had our second AC unit fail in a single
year, wow did it get warm in here real quick.
--- In vantage@yahoogroups.com, "Dale Norris" <dnorris@...> wrote:
> Mike:
> Hope this helps,
> Dale
