[OT] Spam Block List Removal
Todd, I looked up your IP at www.dnsstuff.com in the "Spam Database
Lookup" section at the bottom of the page. It says your are listed in
APEWS and NoMoreFunN.
Its odd that the message doesn't contain any information on which
service has you listed. Don't worry about APEWS too much, the only way
to get off is to wait. No professional server operator would ever use
it. You'll have to look up the removal instructions for the other one.
Brian
Perhaps someone else has fallen into this trap and could advise. An errant PC here got infected and started mass mailing virus laden mail to outside addresses which resulted in our mail IP address being put on several email spam blocking lists. I have removed it from most of them but have one particular case that does not provide the information for removal. The only info provided is:
ESMTP #554 Transaction Failed Spam Message not queued. ##
I suspect that the remaining recipient sites still reporting this may be Exchange 2007 and using Microsoft's anti-spam block lists. Shot of trying to contact the recipients' IT departments to see what they use for block lists I am stumped. All the web searches and Wikipedia info I can find do not have this message.
-Todd Caughey
Harvey Vogel Mfg. Co.
The information contained in this E-mail message and any documents which may be attached are privileged and confidential, and may be protected from disclosure.
Please be aware that any use, printing, copying, disclosure or dissemination of this communication may be subject to legal restriction or sanction. If you think you have received this message in error, please reply to the sender.
For more information please visit www.harveyvogel.com
Todd,
Just a thought, but try changing the outside IP address that your mail
server uses. For example, if your mail.domain.com points to 1.2.3.4,
change it to 1.2.3.5. Make sure you have your provider update the
reverse DNS entries on their side.
Hope this helps.
Jason Claggett
Microsoft Small Business Specialist
MCP #3856159
2W Technologies, LLC
312.533.4033 x8039
jason@...
Of Todd Caughey
Sent: Sunday, August 26, 2007 2:48 PM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] [OT] Spam Block List Removal
-Todd Caughey
from disclosure.
If you have problems in sending mail: A quick fix is using a relay
server (with a different outside IP adress).
In the meantime you can try to get de-blacklisted.
1)
If you have multiple ip adresses available:
Changing the external ip-adres is less time consuming then trying to get
de-blacklisted
Before changing the ip adres, first change the MX-records of your
mailserver:
MX10 new ip adress
MX20 old ip adress
MX30 backup mailserver
etc etc
Wait a few days after the MX change
2)
if you only have ONE ip adress available, try to install a
backupmailserver (if you don't have one)
e.g. on a home ip adress (check if your provider supports smtp on that
backupmailser ip adress)
mailserver:
MX10 new ip adress
MX20 old ip adress
and then change the ip adress to the new adress, if done correctly there
will be no glitch in receiving mail.
Jason Claggett schreef:
> Todd,
> Hope this helps.
> Thanks,
> Jason Claggett
> MCP #3856159
> 312.533.4033 x8039
> jason@...
> Of Todd Caughey
> Thanks,
> -Todd Caughey
> from disclosure.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
> Yahoo! Groups Links
