OT Vantage Bar Codes
Thanks for the reply, Todd. We've already set the scanner to full ASCII.
Regards
Martin Horton
Assistant Group IT Manager
PRD Holdings Ltd
DDI: 01902 639187
Sent: 11 October 2004 17:01
Subject: RE: [Vantage] OT Vantage Bar Codes
Sometime scanners are not set for Extended or Full ASCII character set. You
might have to refer to the scanner's user guide and see if there is perhaps
a bar code to scan from the book that turns this on. It should tell you if
Full-ASCII is on by default or not.
-Todd C.
Sent: Monday, October 11, 2004 10:02 AM
To: Vantage
Subject: [Vantage] OT Vantage Bar Codes
Bar Codes Code 39
Please help I need to generate a barcode ( clocking in cards) within the
report builder with "ALT L" embeded I am using "*%DL%E*" as a user defined
field but this does not seem to work
does anyone have any ideas ?
Krzysztof Dajczak
Group IT Manager
PRD Holdings Limited
Office: +44 (0) 1902 639186
Mobile: +44 (0) 777 1616525
Fax: +44 (0) 1902 639365
E-mail: krzysd@...
www: www.prdholdings.com
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=1292apu0t/M=295196.4901138.6071305.3001176/D=g
roups/S=1705007183:HM/EXP=1097593479/A=2128215/R=0/SIG=10se96mf6/*http://com
panion.yahoo.com> click here
<http://us.adserver.yahoo.com/l?M=295196.4901138.6071305.3001176/D=groups/
S=:HM/A=2128215/rand=504249003>
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
Yahoo! Groups Links
Bar Codes Code 39
Krzysztof Dajczak
Group IT Manager
E-mail: krzysd@...
Sometime scanners are not set for Extended or Full ASCII character set. You might have to refer to the scanner's user guide and see if there is perhaps a bar code to scan from the book that turns this on. It should tell you if Full-ASCII is on by default or not.
-Todd C.
To: Vantage
Bar Codes Code 39
Krzysztof Dajczak
Group IT Manager
E-mail: krzysd@...
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=1292apu0t/M=295196.4901138.6071305.3001176/D=groups/S=1705007183:HM/EXP=1097593479/A=2128215/R=0/SIG=10se96mf6/*http://companion.yahoo.com> click here
<http://us.adserver.yahoo.com/l?M=295196.4901138.6071305.3001176/D=groups/S=:HM/A=2128215/rand=504249003>
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
