Do you want to see the Console session? Or a session thats been
disconnected but still active? I believe the console session is the only
one you can't remote administer. You should have timeout periods setup for
the RDP Client so that the session will end after its been disconnected.
This will keep your resources free. If you sign onto the server via a
Terminal Server session (Non-Console) you can right mouse click on any
session and remotely access it. You have to change some setting on the
Remote Tab of the User setup in Active Diretory.
Hope that helps.
Jeremy Leonard
IT Manager
K-T Corporation
miket@...]
Sent: Friday, May 16, 2003 11:20 AM
To:
vantage@yahoogroups.com
Subject: [Vantage] OT - VPN / Terminal Services conn. to W2K serv.
Is there a way of logging to an existing session on the server using
VPN / Terminal Services? I can connect from home allright, but it
logs me on with a new session and I cannot see the programs already
running on the server. It's Win. 2000 Server, at home Win XP Home
Edition.
Mike Tonoyan / All American Products Co.
miket@...
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
