Well, depending upon whether the server is set to disconnect you or the client, you'd have to make changes in one location or the other. If you've not had disconnects before Windows 7, then I'd start with modifying there.
I think the reg keys you're modifying are incorrect. See Microsoft KB297684 for the correct keys.
http://support.microsoft.com/kb/297684
We've not had any problems with the disconnects other than it freaks people out seeing the red x.
--- In vantage@yahoogroups.com, melissa hietala <kevmel822@...> wrote:
> We are in the process of replacing computers in our CMM lab and we have come across an issue of drives disconnecting intermittently. We have applied a reg edit fix under the DWORD value>Enabled Linked Connections>Modify> Type in 1. This has worked for most machines but for some reason the last couple of days the drives have been disconnecting again. And not always the same drives. We have 6 or 7 different mapped drives on these systems and it's not always the same one disconnecting.
> Â
> Anyone else experiencing this and can send us in a direction to investigate?
> Thanks,
> Melissa Hietala
> UMC, Inc.
> melissah@...
