Our Live Gov Cloud SSRS reports appear to have reverted to a previous version
Just a heads up to everyone that our Live Gov Cloud SSRS reports appear to have reverted to a previous version.
It happened between July 7th and July 8th (Upgrade anyone).
I don’t know the full scope yet - right now i have confirmed the Job Traveler and our PO forms.
If i had to guess - i would bet that somehow Pilot (that got updated the evening of July 7) had something to do with this. Our Live and Pilot were NOT in sync.
I put in a ticket to inquire what happened. I do not know how many documents were affected since our last Pilot DB Refresh was 29-May-2026.
So heads up to others,
DaveO
Wonder if it’s the same issue that happens on-prem. There’s an issue with the common dB and your reports will revert sometimes.
Mr. Chad: Hmmmm - that is pretty scary - we are Gov Cloud and our documents are strictly versioned and controlled to comply with CMMC, Etc.
We cannot have docuements reverting without our knowledge.
If Epicor comes back with always keep Pilot and Live reports in sync then we can do that, but it does make me wonder what happens if i am developing a new version in Pilot but not ready to Go-Live?
Yes, on ours a few of ours reverted to previous versions. 2025.2.20 on prem.
Happened in 24.2 for us. There’s a KB or post on here about why it happens. It started after they moved (sort of) to that common db.
I figured, that’s why we didn’t do a case. We just updated with our backup copies and moved along.
Explosion Remain Calm GIF
Here is the “Elevated Support” answer:
**KB0144073 provides the logic used by Kinetic 2025.2 to determine if the deployed version of an SSRS report is the most recent copy, which is the only mechanism that would redeploy a custom SSRS report without a customer explicitly importing a changed version in Report Style Maintenance (or Solution Workbench).
What happens when you print a custom SSRS Report Style?
  1. Has the latest version of the custom report in question been printed from this Kinetic environment in the last 30 minutes?
If yes: run report.
If no: proceed to the next step.
  1. Is there a copy of this Report Style’s PrintProgram–the latest version of the custom report in question–in Ice.CustomReportStore ?
If yes: proceed to the next step.
If no: receive an error similar to “The item ‘/xxxxx/reports/CustomReports/AgedReceivablesReport/AgdRcv’”. Custom report files may need to be reimported from a backup.
  1. Is custom report deployed under the relative PrintProgram folder in the Kinetic SSRS root?
If yes: take the deployed SSRS report artifacts, zip them up virtually, and generate a checksum. Proceed to the next step.
If no: becauseIce.CustomReportStore is the source of truth, overwrite the deployed artifacts with the latest version from Ice.CustomReportStore, then run the report.
  1. Does the checksum of the deployed custom report match the checksum of what’s Ice.CustomReportStore for this PrintProgram?
If yes: run the report.
If no: overwrite the deployed artifacts with the latest version from Ice.CustomReportStore, then run the report.
This “check, compare, maybe redeploy” and “validate, check, compare, maybe redeploy” logic can be disabled as of Kinetic 2026.100.7 by running Conversion Workbench Conversion 430 (description: Deploy reports to SSRS Server from Kinetic database). As of Kinetic 2027.100 the system will automatically run Conversion 430.
Knowledge Article KB0144073 - Understanding How SSRS Report Styles Are Processed in Kinetic (WhitePaper)**
Even after that lengthy techno babble I do not understand. Apparently there is a conversion we can run to stop Epicor from doing this and it will be run as a default as of 2027.x?
Whaaaat?
It’s not great… keep backups of all your reports!
Mr. Chad: Since in our situation the LIVE reports were reverted to a previous version when Pilot was updated that is a Crazy scenario. How do we explain that to auditors? The Job Traveler and PO stuck out for us but it does beg the question how many other forms were reverted to prior versions. The reports all work - they are just a reverted version.
If we fix a Typo that may get lost and we may not find it or know about it until someone notices.
This is Crazy Wrong!
DaveO
Similar to, where some mention PRD being affected.
