Outlook hangs when opening attachment while Vantage is running
How do you start vantage with a command line shortcut? Are you bypassing .vtg file altogether?
Sent: Tuesday, March 13, 2001 10:19 AM
Subject: Re: [Vantage] Outlook hangs when opening attachment while Vantage is running
Here is the likely problem...
If you "end task" on vantage.exe in task manager after
vantage is started it will probably work. Other than that
you can start vantage with a command line shortcut like
version 3 did to bypass the splash screen.
2-26-01 670350MPS - OPEN - SCR 1659
Various computers cannot run various programs when Vantage is running.
QC and the foreman's
office cannot run excel. Dave Stultz cannot run Autocad. Jodi cannot
run Winfax from
report Builder. Shelly and I cannot email from excel. This is a bug in
vantage. Users
should end-task on vantage.exe after starting vantage (vantage will stay
running).
The splash screen is stuck on causing this problem.
Running vantage from the command line (or a shortcut) can bypass this
problem.
Resolution:
SCR 1659, planned for Vantage 5.00
Tester's note: This problem occurs on some computers, such as Marcy's,
but
not others.
Prior to Cairo, the Vantage executable (vantage.exe) would go away when
Vantage took down the splash screen. As of Vantage 5.00.005 -- did not
find
an SCR for this change -- the vantage.exe program keeps running until
the
user exits Vantage. Per Development, the program should quit when the
splash screen comes down.
kblaine@... wrote:
> Saw some mention of this on the list already, so perhaps one of you already
> on Vantage 5.0 has found a way to deal with this:
> Ever since our upgrade to 5.0, we have noticed that our Windows 95/98 PCs
> hang and need to be rebooted if you try to open an email attachment in
> Outlook 98 (attachments open fine if Vantage was never started).
> Vantage Tech Support acknowledges this has something to do with their
> software and they have the issue under investigation, but I was wondering if
> anyone else was suffering from the same problem? We are on patch 306, but
> I'm told patch 312 doesn't remedy this problem, either. It would be
> interesting to know if this affected everyone who upgraded to 5.0 (strength
> in numbers and all that). Thanks!
> Karen Blaine
> _____________________________
> Karen Blaine
> Information Systems Administrator
> Three M Tool & Machine
> 248.363.1555 x220
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
run Winfax from
vantage. Users
running).
problem.
Resolution:
but
not others.
find
the
> Karen Blaine
> Karen Blaine
> 248.363.1555 x220
"command line"? Do you mean just creating a standard shortcut on the
desktop to fix it?
Wendy Bowen
Network Administrator
Schmald Tool & Die, Inc.
(810) 743-1600 ext.323
wpursche@...
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Tuesday, March 13, 2001 11:18 AM
is running
> run Winfax from
> vantage. Users
> running).
> problem.
> Resolution:
> but
> not others.
> find
> the
already
PCs
wondering if
but
(strength
> > Karen Blaine
> > Karen Blaine
> > 248.363.1555 x220
