Output Format
In my example I will use Sales Order Acknowledgement Report. It defaults the Output Format to PDF. Can I default it to something else? Where and how can I do this?
There isn’t a builtin way to change the default print preview format within the drop down from PDF.
I know you can make the default format EMF by adding reports that should default to that format to a key in the appserver’s web config file
<add key="EMFReports" value="POForm;OrderAck" />
The web.config adjustments for EMFReports effects printing only, specifically/mainly/solely(?) for APM processing.
Though, one could use Advanced Print Routing/Auto-printing to mimic a different default, but, it isn’t exactly the same thing.
Thanks for the feed back! In my case the web.config mod will work.
Hello,
What is the key for the CSV report? I tried the following which did not work.
