Overtime Pay Rate E9
Only problem is that it requires the workers to log out of their jobs and clock out after 8 hours and clock into a different shift then log back into their jobs. It would completely depend on the discipline of the labor force.
We export our labor hours and calculate whether overtime is due in Crystal. Since we sometimes work 4-10s or shift working days, we do this by summing the week and doing the calculations based on: if totalhours <= 40 then rate * totalhours else (rate * 40) + ((rate * 1.5) * (totalhours - 40)). Should be simple enough to adjust for a daily overtime calculation instead.
hth, Kirstin
--- In vantage@yahoogroups.com, Steven M Carr <Steven.Carr@...> wrote:
> Our client would like to have overtime cost etc. calculated after an 8 hour day for Job work.
> They do not have payroll.
> Original thought is to create a second shift, shift 11 that has a differential of 1.5 and set to always.
> When an employee works a 10 hour day we will enter labor as Shift 1: 8 hours, Shift 11: 2 hours.
> Shift 11 would also be used for weekend work.
> Looking if anyone has any other ideas they are using currently.
> Steven M. Carr
> Crawford Software Consulting, Inc. (CSCI)
> "Bringing Software and Manufacturing Together"
> Please note - new efax number
> Email: Steven.Carr@...
> Phone: (603) 537 - 9630 x 111
> Mobile: (603) 264 - 7010
> Fax: (603) 537 - 9633
> Efax: (603) 386 - 6671
> Website: www.Crawford-Software.com
> [Description: http://www.crawford-software.com/sap_partner_R_tm_p.jpg%5d<http://www.crawford-software.com/SAPOverview.htm> [Description: WinshuttlePartnerNetworkSmall] [Description: Small Global Certified Partner Logo] [Description: Epicor Certified Consulting Partner]
> Notice: This electronic transmission is strictly confidential to Crawford Software Consulting, Inc. (CSCI) and intended solely for the addressee. It may contain information, which is covered by legal, professional, or other privilege. If you are not the intended addressee, or someone authorized by the intended addressee to receive transmissions on the behalf of the addressee, you must not retain, disclose in any form, copy or take any action in reliance on this transmission. If you have received this transmission in error, please notify the sender as soon as possible and destroy this message. Contact CSCI at (603) 537-9630.
Steven M. Carr
