I changed the file name as you suggested. At this point, I no longer get an error message, but I don't have a test.xml file, either. I took Karen's suggestion to look in my server log file. There are NO messages in the file at or after the time I change an order release. Just to ensure the event was getting triggered, I also have an email sent out at the same time. I get the email just fine.
Here is my revised code:
{ud/GlbAlert.i &TableName = "Orderrel"}
define variable OutputXMLFileName as character no-undo.
OutputXMLFileName = 'c:\test.xml'.
if not DumpRecordAsXMLFile(input OutputXMLFileName) then return error.
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
"The World Leader in Back-lit Mirrors & Mirror TV Technology"
T 425 776-4946
F 425 491-8200
AÂ 11831 Beverly Park Rd, Bldg D, Everett, WA 98204Â USA
www.electricmirror.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of DD
Sent: Friday, February 20, 2009 12:18 PM
Subject: Re: [Vantage] .p program newbie question
Check the OutputXMLFileName = '\\db1\Epicor\ ' Is there a space in the filename after the last \ ?
Is there permission to write to \\db1\Epicor? You might try writing to "C:\test.xml" to see if there is a problem with the filename.Â
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
T 425 776-4946
F 425 491-8200
--- On Fri, 2/20/09, Thomas Rose <t.rose@...> wrote:
Subject: [Vantage] .p program newbie question
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Date: Friday, February 20, 2009, 1:59 PM
I'm trying my first progress program. I have it set up to run as an alert program when an order release is updated. I want to dump my order release record as an xml file. I copied the code almost verbatim from the example on p. 467 of the Epicor Tools User Guide. The notable exception is that I changed the output file name and I dropped the comments. Here is my code:
{ud/GlbAlert. i &TableName = "Orderrel"}
OutputXMLFileName = '\\db1\Epicor\ ' + string(orderrel. ordernum) + '-' + string(orderrel. orderline) + '-' + string(orderrel. orderrelnum) + '.xml' .
if not DumpRecordAsXMLFile (input OutputXMLFileName) then return error.
When I turn on the alert, I get the following error/stack trace whenever I update an order release. What am I doing wrong?
Error Detail
4GL STOP condition: The Server application has returned an error. (7243) (7241)
Stack Trace
at Progress.Open4GL. DynamicAPI. Session.runProce dure(String requestID, String procedureName, ParameterSet parms, Boolean persistent, Boolean internal_Renamed, Int64 procId, MetaSchema localSchema, Int32 stateModel)
at Progress.Open4GL. DynamicAPI. Session.runState lessProcedure( String requestID, String fullProcedureName, ParameterSet inparams, Object procId, MetaSchema localSchema, Int32 stateModel)
at Progress.Open4GL. DynamicAPI. PersistentProc. runTheProcedure( String requestID, String procedureName, ParameterSet parms, MetaSchema schema)
at Progress.Open4GL. DynamicAPI. PersistentProc. runProcedure( String procedureName, ParameterSet parms, MetaSchema schema)
at Epicor.Mfg.Proxy. SalesOrderImpl. Update(SalesOrde rDataSet ds)
at Epicor.Mfg.UI. Adapters. SalesOrderAdapte r.Update( )
at Epicor.Mfg.UI. App.SalesOrderEn try.Transaction. Update()
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
T 425 776-4946
F 425 491-8200
www.electricmirror. com
