Does anyone know what version they removed the column filters in Pack Search? And the reasoning behind it?
Heh… I went back and forth with support over this for weeks. Epicor removed it 25. They were using a filtering control from Microsoft that Microsoft removed in .NET 8 or 9. Instead of taking the time to implement the Microsoft replacement Epicor just removed it. Their suggestion is to just click through the list till you find your shipment. ![]()
I created an external BAQ pointing to the dbo.Shipment table in the QS dB and rebuilt the pack search. If you’re cloud you’re SOL. But if you’re on-prem you can create your own workaround.
The poor Epicor support person tried to submit an idea and Epicor wouldn’t approve it. So likely not coming back.
Ah, thanks for this. Very disappointing.
Very.
