Package Code Truncated on Subcontract Pack Slip
Thanks but the same table is used by customer shipment packing slip (which
works) and we have defined codes such as; 1 Skid, 2 skids, ... to 10 skids
and 1 box, 2 boxes, 3 boxes.... and 1 Pan, 2 Pans,.... so that on the
packing slip the code suffices as the description (which Epicor did not see
fit to include in the dbf like so many other useful fields!). But the
calculated field bit might be my last resort and I could change the other
packing slip to match. Biggest problem would be all the current codes that
can't be deleted because they've been used.
-Todd
Sent: Thursday, August 15, 2002 9:11 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Re: Package Code Truncated on Subcontract Pack Slip
If you don't have more than 20 codes or so you could create a calculated
field in the form to translate the code to whatever description you want.
This could be a quick & easy fix.
Patrick
Sent: Thursday, August 15, 2002 9:02 AM
Slip
I called them. They seemed to not have heard of it before. Lost? Ignored?
Anyway, they said it would be noted and maybe in a future patch release
would be fixed. In the mean time, since we do nto use Lot id at all I am
considering in the VB Form I already have on SubShipD having the OK button
shove the package code (from the main screen) into the lot field (which is
available in the dbf). Probably won't work but maybe worth a try. Our 8
digits codes are all the description we really need but 3 digits won't cut
it.
-Todd
Sent: Thursday, August 15, 2002 8:51 AM
Subject: [Vantage] Re: Package Code Truncated on Subcontract Pack Slip
Todd,
I too ran into this problem. I discovered it a couple of years ago
during implementation of 4.0. I notified Tech Support of the "Bug"
and they shrugged it off as not being a critical issue, so I
shouldn't hold my breath about it getting fixed. I also wanted to
see the description on the Sub-Contract Packing Slip. So, I created
a work around. First, I changed all the packaging codes for Sub-
Contract Items to 3 characters. Second, I linked the Packing Table
to the SubShipD Table in the Sub-Contract Packing Slip with the
Package Code field, via ODBC (Merant 3.6 (not SQL92)). This allowed
me to display the Description and therefore I don't even worry about
displaying the 3 character abbreviation. It would be interesting to
find out what Tech Support would tell you now. If you do call them,
let me know.
HTH,
Brian Stenglein
Clow Stamping Co.
--- In vantage@y..., Todd Caughey <caugheyt@h...> wrote:
> I have discovered the the packaging code supplied to the .DBF file
for the
> Subcontractor Packing Slip is truncated to three (or less)
characters. The
> field is actually 8 characters in the database but when I examine
the dbf
> file with Excel it shows only the first 2 or three characters and
in Crystal
> the format is shown as 'XXX'. On the regular customer shipment
packing slip
> it exports all 8 characters to the dbf file. This looks to me like
a bug
> and I was wondering if anyone else had experienced this or know if
Epicor is
> already aware of it. I have verified this exists up to verison
5.10. I
> would really like to get the package code (better yet the
description)
> printed on our packing slips (something like "40 packages shipped
as 2
> skids") so that the truck driver and the receiving people at the
vendor can
> verify they have the received the correct package configuration.
Currently
> it would print as "40 packages shipped as 2 ski" which won't work
> until late November. ;)
> To report something like this do I just make a regular support call
and let
> them note it for future release attention?
> Thanks,
> -Todd Caughey
> Harvey Vogel Mfg Co.
Yahoo! Groups Sponsor
ADVERTISEMENT
http://rd.yahoo.com/M=231049.2208958.3660596.1829184/D=egroupweb/S=17050071
<http://rd.yahoo.com/M=231049.2208958.3660596.1829184/D=egroupweb/S=17050071
83:HM/A=1175203/R=0/*
http://www.gotomypc.com/u/tr/yh/grp/300_06/g22lp?Target
<http://www.gotomypc.com/u/tr/yh/grp/300_06/g22lp?Target>
=mm/g22lp.tmpl>
< http://groups.yahoo.com/group/vantage/files/.
<http://groups.yahoo.com/group/vantage/files/.> >
< http://groups.yahoo.com/group/vantage/messages
<http://groups.yahoo.com/group/vantage/messages> >
< http://groups.yahoo.com/group/vantage/links
<http://groups.yahoo.com/group/vantage/links> >
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
ADVERTISEMENT
I have discovered the the packaging code supplied to the .DBF file for the
Subcontractor Packing Slip is truncated to three (or less) characters. The
field is actually 8 characters in the database but when I examine the dbf
file with Excel it shows only the first 2 or three characters and in Crystal
the format is shown as 'XXX'. On the regular customer shipment packing slip
it exports all 8 characters to the dbf file. This looks to me like a bug
and I was wondering if anyone else had experienced this or know if Epicor is
already aware of it. I have verified this exists up to verison 5.10. I
would really like to get the package code (better yet the description)
printed on our packing slips (something like "40 packages shipped as 2
skids") so that the truck driver and the receiving people at the vendor can
verify they have the received the correct package configuration. Currently
To report something like this do I just make a regular support call and let
-Todd Caughey
Todd,
let me know.
HTH,
Brian Stenglein
Clow Stamping Co.
for the
characters. The
the dbf
in Crystal
packing slip
a bug
Epicor is
5.10. I
description)
as 2
vendor can
Currently
and let
> Thanks,
> -Todd Caughey
it.
-Todd
Todd,
let me know.
HTH,
Brian Stenglein
Clow Stamping Co.
for the
characters. The
the dbf
in Crystal
packing slip
a bug
Epicor is
5.10. I
description)
as 2
vendor can
Currently
and let
> Thanks,
> -Todd Caughey
ADVERTISEMENT
83:HM/A=1175203/R=0/*http://www.gotomypc.com/u/tr/yh/grp/300_06/g22lp?Target
=mm/g22lp.tmpl>
Patrick
Slip
it.
-Todd
Todd,
let me know.
HTH,
Brian Stenglein
Clow Stamping Co.
for the
characters. The
the dbf
in Crystal
packing slip
a bug
Epicor is
5.10. I
description)
as 2
vendor can
Currently
and let
> Thanks,
> -Todd Caughey
ADVERTISEMENT
=mm/g22lp.tmpl>
