PackSlip.rpt summarize data
I see now that Group Header/Footer # 1 is for the OrderNum.
I see Group # 2 is ShipDtl.OrderLine_ParentKitLine; I'm not sure of
the result of using this Group since I've never used kits.
You should add your own (third) Group and group on
ShipDtl.OrderLine_OrderLine. You can supress Group Header #3 and
insert your Summary into Group Footer # 3.
Lynn
--- In vantage@yahoogroups.com, "vantage_steve" <stevek@...> wrote:
> Lynn,
> Thank you. This worked very well for my example. Then we tried an
> order with more than one part number and it kept a total for the
> whole order. Is there a way with running totals or summary to make
> totals for each part on the packslip.
> Thank you.
> --- In vantage@yahoogroups.com, "Lynn" <lynn.khalife@> wrote:
> > Assuming that you are using a copy of the Epicor-provided
> > packslip.rpt, then it should be easy to do what you want.
> > Use Section Expert to supress the detail section where the Lines
> are
> > printed.
> > Then make the Group Footer # 1 section larger.
> > Right-Click on the (now supressed) shipdtl.Calc_DspLineShipQty
> field
> > in the details section. Choose Insert--Summary to tell CR to
make
> a
> > total and tell it what section to place the total. Select Group
> 1
> > for the placement of the total. Now you can format the Group #1
> > section any way you want.
> > Lynn
> > --- In vantage@yahoogroups.com, "vantage_steve" <stevekunzman@>
> > wrote:
> > > We have created a sales order for a part from three different
> lots.
> > > Order line 1 part=971 qty=384 lot=x
> > > Order line 2 part=971 qty=288 lot=y
> > > Order line 3 part=971 qty=192 lot=z
> > > Packing slip shows all three lines but we want to only see one
> line
> > > with the total qty for the part.
> > > part=971 qty=864
> > > How can this be done in crystal reports?
> > > Vantage 803 crystal 11.5
> > > Thank you.
We have created a sales order for a part from three different lots.
Packing slip shows all three lines but we want to only see one line
part=971 qty=864
Thank you.
Use Section Expert to supress the detail section where the Lines are
printed.
Right-Click on the (now supressed) shipdtl.Calc_DspLineShipQty field
in the details section. Choose Insert--Summary to tell CR to make a
total and tell it what section to place the total. Select Group # 1
Lynn
--- In vantage@yahoogroups.com, "vantage_steve" <stevekunzman@...>
> part=971 qty=864
> Thank you.
Lynn,
Thank you.
are
> printed.
field
a
1
> Lynn
lots.
line
> > part=971 qty=864
> > Thank you.
