http://bit.ly/14SOGXc
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
On Fri, Jul 5, 2013 at 4:45 PM, clederer@... <
clederer@...> wrote:
*Jose C Gomez*
*Software Engineer*
E: jose@...
> **[Non-text portions of this message have been removed]
> Ideally, I'm writing a template for the template of a check.
> The check number needs to be 8 digits with zeros leading the field, then
> the check number
> x = any number (Fixed number of 8 digits, cant be less or greater)
> If Length of X is less than 8, pad the required amount of 0's in the front
> to make its length 8. Result should also be a number and not a string.
> Eg:
> X = 123
> Result of Formula should be 00000123
> X = 9
> Result of Formula should be 00000009
> Does anyone know how to do this in Crystal Reports? Right now there are no
> zeros leading
