Parameter select statement in Crystal
Ah, now I see. It's case sensitive. I wonder if there is a way around the case sensitivity of the command. Otherwise I think it will work the best.
Troy Funte
Liberty Electonics
----- Original Message -----
Sent: Friday, October 25, 2002 4:46 PM
Subject: [Vantage] Re: Parameter select statement in Crystal
Troy,
I think you can use the "In String" operator to accomplish your
objective. Here is the relevant text from Crystal Help:
In String operator
Basic and Crystal syntax.
Usage
x in y
Tests for the presence of string x in string y.
Examples
The following examples are applicable to both Basic and Crystal
syntax:
"Elm" in {customer.ADDRESS1}
TRUE, where {customer.ADDRESS1} is "1335 Elm Street".
TRUE, where {customer.ADDRESS1} is "1335 Elmer Street".
"elm" in {file.MOTTO}
FALSE, where {file.MOTTO} = "Feel more energy".
(The "el" ending "feel" and the "m" beginning the word "more" are
separated by a space which itself counts as an element.)
"el m" in {file.MOTTO}
TRUE, where {file.MOTTO} = "Feel more energy".
The search string "el m" this time contains the space between the l
and the m, which allows for a perfect match.
Note: The "in" operator can also be used to test for the presence
of a string in a text range. For example, "V5B" in "V0A" to "V9Z".
--- In vantage@y..., "Jim Stetter" <jim.stetter@b...> wrote:
> Troy, I neglected to read your entire request. Perhaps this method
would
> work.
> Create a parameter field "promptvendor" to receive user input.
> Created a formula field, call it SelectVendor = if
> InStr({Vendor.Name},{?promptvendor}) > 0 then true else false
> Then edit the select filter to include @SelectVendor similar to
below (this
> won't make sense in the example below but illustrates how to do
it.) Note:
> this could cause a for a lengthy query but will work.
> {Company.Company} = "SN2" and
> {OrderRel.OpenRelease} and
> {OrderDtl.OpenLine} and
> {OrderHed.OpenOrder} and
> {Customer.SalesRepCode} startswith ["3", "7"] and
> {@SelectVendor}
> Jim Stetter
> -----Original Message-----
> From: Troy Funte [mailto:tfunte@e...]
> Sent: Friday, October 25, 2002 3:14 PM
> To: Vantage
> Subject: [Vantage] Parameter select statement in Crystal
> Hi gang,
> I'm looking for a way in Crystal to for the user to type just
part of
> the
> Vendor Name as input. Crystal would then bring up and vendor
names that
> match.
> For instance, if the user entered, "sam", then Crystal would find
matches
> like "samuel", "sammy", "samantha", "chissam", etc.
> It should be a piece of cake, but I can't get it....
> Troy
> Yahoo! Groups Sponsor
> ADVERTISEMENT
must
> have already linked your email address to a yahoo id to enable
access. )
Builder and
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
ADVERTISEMENT
Hi gang,
I'm looking for a way in Crystal to for the user to type just part of the
Vendor Name as input. Crystal would then bring up and vendor names that
match.
For instance, if the user entered, "sam", then Crystal would find matches
Troy
Hello Troy
I have never played with what you're trying to do, but this might work?
http://support.crystaldecisions.com/library/kbase/articles/c2007779.asp
<http://support.crystaldecisions.com/library/kbase/articles/c2007779.asp>
Dan Shallbetter
States Electric Mfg.
Sent: Friday, October 25, 2002 2:14 PM
To: Vantage
Hi gang,
match.
Troy
Dan,
Thanks for the reply. Using wildcards is one option I am looking into. I would like, however, for the user to not have to enter wildcards, just a phrase. Then Crystal would do the rest.
Troy Funte
Liberty Electronics
To: 'vantage@yahoogroups.com'
Sent: Friday, October 25, 2002 3:32 PM
Subject: RE: [Vantage] Parameter select statement in Crystal
Hello Troy
Dan Shallbetter
To: Vantage
Hi gang,
match.
Troy
ADVERTISEMENT
Doesn't the Soundex function do something like picking phrases?
-Todd C.
Sent: Friday, October 25, 2002 2:42 PM
Subject: Re: [Vantage] Parameter select statement in Crystal
Dan,
Troy Funte
Liberty Electronics
Hello Troy
< http://support.crystaldecisions.com/library/kbase/articles/c2007779.asp
<http://support.crystaldecisions.com/library/kbase/articles/c2007779.asp> >
Dan Shallbetter
To: Vantage
Hi gang,
the
match.
Troy
ADVERTISEMENT
ADVERTISEMENT
<http://rd.yahoo.com/M=237459.2482214.3917349.2146399/D=egroupweb/S=17050071
83:HM/A=1267611/R=0/*http://ad.doubleclick.net/jump/N2524.Yahoo/B1071650;sz=
300x250;ord=1035574940103651?>
<http://us.adserver.yahoo.com/l?M=237459.2482214.3917349.2146399/D=egroupmai
l/S=:HM/A=1267611/rand=433610664>
Troy,
Use something similar to:
{Vendor.Name} startswith ?vendorname
Jim Stetter
Sent: Friday, October 25, 2002 3:42 PM
Dan,
Troy Funte
Liberty Electronics
Hello Troy
Dan Shallbetter
To: Vantage
Hi gang,
the
match.
matches
Troy
ADVERTISEMENT
ADVERTISEMENT
Todd
I never heard of that function before. After reading help (Use this function whenever you want to locate records based on two or more field values that are spelled differently yet sound alike. This function can also be used to find customer names that have been misspelled.) it doesn't look appear to be what I'm looking for. Thanks for the suggestion.
Troy Funte
Liberty Electronics
Sent: Friday, October 25, 2002 3:59 PM
-Todd C.
Dan,
Troy Funte
Liberty Electronics
Hello Troy
Dan Shallbetter
To: Vantage
Hi gang,
the
match.
Troy
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
It's a neat little function. But it translates entire words into an
abbreviated phonetic representation. Names like Johnson and Jensen would
translate into the same code, so a search for one would get both. But it
doesn't help with partial matches like he asked.
-Wayne Cox
Twenty Three -- Information Technology Consulting
828-685-2338
That would work if they entered the beginning of the name, but how about if they wanted to enter a word in the middle of the vendor name?
Troy Funte
Liberty Electronics
Sent: Friday, October 25, 2002 4:14 PM
Troy,
Jim Stetter
Dan,
Troy Funte
Liberty Electronics
Hello Troy
Dan Shallbetter
To: Vantage
Hi gang,
the
match.
matches
Troy
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Troy, I neglected to read your entire request. Perhaps this method would
work.
Then edit the select filter to include @SelectVendor similar to below (this
won't make sense in the example below but illustrates how to do it.) Note:
{@SelectVendor}
Jim Stetter
To: Vantage
Hi gang,
the
match.
Troy
ADVERTISEMENT
Troy,
In String operator
Usage
x in y
Examples
syntax:
would
> work.
below (this
it.) Note:
> {@SelectVendor}
> Jim Stetter
> To: Vantage
> Hi gang,
part of
> the
names that
> match.
matches
> Troy
> ADVERTISEMENT
must
access. )
Builder and
Service.
Troy,
I tested the solution I sent to you. Unfortunately, it seems the InStr
function is case sensitive. There is also InstrRev function which searches
the string in reverse order and will accept an argument to indicate case
sensitivity.
Something like this should work:
if instrrev ({vendor.name},{promptvendor},-1,1) > 0 then true else false
the -1 says to start at last character, the 1 makes the search case
insensitive.
Let me know if this works for you.
Jim Stetter
Sent: Friday, October 25, 2002 4:26 PM
Troy Funte
Liberty Electronics
Troy,
Jim Stetter
Dan,
I
Troy Funte
Liberty Electronics
Hello Troy
work?
Dan Shallbetter
To: Vantage
Hi gang,
part of
the
that
match.
matches
Troy
ADVERTISEMENT
must
Builder
ADVERTISEMENT
and
ADVERTISEMENT
ADVERTISEMENT
I was just trying this and getting no results. I'll try your other suggestion.
Troy Funte
Liberty Electronics
Sent: Friday, October 25, 2002 4:28 PM
work.
{@SelectVendor}
Jim Stetter
To: Vantage
Hi gang,
the
match.
Troy
ADVERTISEMENT
ADVERTISEMENT
