Parent/Child UD Tables Retrieved via UltraComboBoxes from Other
Rob,
You rock as always!
It was the "myHash.Add("UD102A",wClause)" that I needed to get the 'wClause' into the search.
NB
--- In vantage@yahoogroups.com, "Rob Bucek" <rbucek@...> wrote:
> Nathan,
> Here is a customization I wrote that I think fairly emulates what you're
> trying to do if I read that correctly. We have a root cause analysis
> report we do for late shipments to customers. Our account managers
> wanted a reason code, and for each reason code, a group of sub codes
> tied to the 'parent' code. I set up a UD parent child table to hold the
> parent codes and child table to hold the 'sub' codes. In addition just
> in case, you'll also set up one FKV for your child table in the data
> tools dialogue that you won't see in the code below. There are also
> some addition unrelated things going on in here you'll need to look past
> (such as the hash table I'm using for looking up crap on the part
> table). Hope this helps.
> Module Script
> '// ** Wizard Insert Location - Do Not Remove 'Begin/End
> Wizard Added Module Level Variables' Comments! **
> '// Begin Wizard Added Module Level Variables **
> '// End Wizard Added Module Level Variables **
> '// Add Custom Module Level Variables Here **
> Private WithEvents oTrans_adapter As EpiBaseAdapter
> Private UD102Adapter As UD102Adapter
> Sub InitializeCustomCode()
> UD102Adapter = New UD102Adapter(oTrans)
> UD102Adapter.BOConnect()
> oTrans_adapter = csm.TransAdaptersHT("oTrans_adapter")
> End Sub
> Private Sub FillUD102ACombo(Key1 as String)
> Dim myHash As System.Collections.Hashtable = New
> System.Collections.Hashtable()
> Dim wClause As String = "Key1= '" & Key1 & "'"
> 'MessageBox.show(wClause)
> Dim opts As SearchOptions =
> Epicor.Mfg.UI.Searches.SearchOptions.CreateRuntimeSearch(myHash,DataSetM
> ode.RowsDataSet)
> ud102Adapter.InvokeSearch(opts)
> End sub
> Private Sub ucbSubReason_BeforeDropDown(ByVal Sender As Object,
> ByVal Args As System.ComponentModel.CancelEventArgs) Handles
> ucbSubReason.BeforeDropDown
> Dim edvUD09 As EpiDataView =
> CType(oTrans.EpiDataViews("UD09"),EpiDataView)
> Dim Key1 As String = edvUD09.dataView(edvUD09.Row)("ShortChar02")
> FillUD102ACombo(Key1)
> End Sub
> '// ** Wizard Insert Location - Do not
> delete 'Begin/End Wizard Added Variable Intialization' lines **
> '// Begin Wizard Added Variable
> Intialization
> '// End Wizard Added Variable
> Intialization
> '// Begin Custom Method Calls
> '// End Custom Method Calls
> 'End Sub
> Sub DestroyCustomCode()
> ud102Adapter.Dispose()
> ud102Adapter=Nothing
> oTrans_adapter = Nothing
> delete 'Begin/End Wizard Added Object Disposal' lines **
> '// Begin Wizard Added Object Disposal
> '// End Wizard Added Object Disposal
> '// Begin Custom Code Disposal
> '// End Custom Code Disposal
> End Sub
> Private Sub oTrans_adapter_BeforeAdapterMethod(ByVal
> sender As object, ByVal args As BeforeAdapterMethodArgs) Handles
> oTrans_adapter.BeforeAdapterMethod
> '// ** Argument Properties and Uses **
> '// args.MethodName, args.Cancel
> 'Add Event Handler Code
> 'MessageBox.Show(args.MethodName) ' use this to find
> method
> Select Case args.MethodName
> Case "Update"
> Dim edvPart As EpiDataView =
> CType(oTrans.EpiDataViews("Part"),EpiDataView)
> Dim strDesc As String =
> edvPart.dataView(edvPart.Row)("PartDescription")
> Dim txtKey1 as epitextbox =
> ctype(csm.GetNativeControlReference("46567b2e-6bc0-4967-be35-a0ec6843838
> f"),EpitextBox)
> Dim val As String = txtKey1.value
> Dim WhereCLause As String = "PartNum = '" + val + "'"
> Dim recSelected As Boolean
> Dim dsSearch As DataSet
> 'MessageBox.Show (strDesc)
> If (val <> String.Empty) Then
> dsSearch =
> Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(oTrans,"PartAdapt
> er",recselected,False,whereClause)
> If (recSelected = False) Then
> 'MessageBox.Show (val + "is not a valid part.")
> 'edvUD09.dataView(edvUD09.Row)("ShortChar01") = ""
> End If
> 'MessageBox.Show (val)
> edvUD09.dataView(edvUD09.Row)("ShortChar01") = strDesc
> End If
> 'Throw New UIException
> Case Else
> End Select
> End Sub
> Private Sub UD09Form_Load(ByVal sender As object, ByVal
> args As EventArgs) Handles UD09Form.Load
> '// Add Event Handler Code
> Dim fields As String() = New String(){"ChildKey1"}
> ucbSubReason.DataSource = ud102Adapter.UD102Data.UD102A
> ucbSubReason.ValueMember = "ChildKey1"
> ucbSubReason.DisplayMember = "ChildKey1"
> ucbSubReason.SetColumnFilter(fields)
> End Sub
> Private Sub ucbSubReason_ValueChanged(ByVal Sender As
> Object, ByVal Args As System.EventArgs) Handles
> ucbSubReason.ValueChanged
> '// ** Place Event Handling Code Here **
> f"),EpitextBox)
> dsSearch =
> End If
> End If
> End Sub
> Rob Bucek
> Manufacturing Engineer
> PH: (715) 284-5376 ext 3111
> FAX: (715)284-4084
> <http://www.dsmfg.com/>
> (Click the logo to view our site) <http://www.dsmfg.com/>
> Of bonner.nathan
> Sent: Friday, November 06, 2009 11:08 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Parent/Child UD Tables Retrieved via UltraComboBoxes
> from Other Menues
> We are on 8.03.408B.
> I have setup a Parent / Child User Defined Table for Customers'
> "Industry" (Parent) and related "Segments" (Child). I want to use two UD
> Fields on Customer (ShortChar04 and ShortChar05) to hold these values
> returned via selections made from two Ultra Combo Boxes (UCB's).
> I have been able to get the Parent selections to appear correctly in the
> first UCB but am struggling to get the Child selections to filter
> correctly based on the Parent selection.
> The segment of my code that I suspect may be the problem is as follows
> and it is better use of the "wClause" that seems to be wanting:
> Private Sub FillUD101ACombo(key1 As String)
> Dim wClause As String = "Key1 = '" & Key1 & "'"
> 'MessageBox.Show("UD101A", wClause)
> ode.RowsDataSet)
> ud101Adapter.InvokeSearch(opts)
> End Sub
> Any suggestions on how to pass the "wClause" to the Search to limit the
> returns?
> Thanks,
> NB
