Part Class Issue
I think I may have found a solution. I tested this again and received the
same results, so I went into the Part Class again, tabbed through the
account fields, then created another purchase order. This time the system
debited and credited the correct control account. I guess I just need to
tab through all of the account fields for the inactive classes. I have had
to do this on some sales orders to allow credit memos to be posted to them
and I have no idea why but it works. Would be nice if you could mark these
inactive and not have them appear at all.
Michael
> -----Original Message-----
> From: Karen Brodniak [mailto:karen.brodniak@...]
> Sent: Thursday, June 05, 2003 1:46 PM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Part Class Issue
> We were having the same problem and sometimes still do. Our
> problem happened
> when we restructured the Part Classes and a PO was copied that used a
> different part class. When the item was received, it would post to an
> inactive GL account. I asked the Purchasing Agent to keep an eye on copied
> PO's and make sure the part class is the correct one.
> Karen Brodniak
> Accounting Manager
> 425-742-7011 X44
> Fax 425-353-8945
> karen.brodniak@...
> From: Michael Benedict [mailto:mbenedict@...]
> Sent: Thursday, June 05, 2003 10:54 AM
> Subject: [Vantage] Part Class Issue
> We have consolidated our part classes into a more manageable number over
> the
> last few months. We renamed the description to have the
> inactive classes
> fall to the bottom of the sort and removed all of the associated GL
> account
> numbers in Part Class Maintenance. However, if someone selects
> one of the
> invalid classes by mistake the settings are somehow stored in the system
> and
> the previously referenced GL account number, active or not, will be
> charged.
> When I look at the account settings in the maintenance screen
> they are all
> blank, but if I create a report and include the ID, Desc and GL Expense
> Account info, the GL Expense Account appears on the reports. Has anyone
> else experienced this, or am I not looking in the appropriate location?
> Thanks in advance,
> Michael Benedict
> IS Manager
> Crestview Aerospace Corp.
> Yahoo! Groups Sponsor
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> Builder and
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
> must have already linked your email address to a yahoo id to
> enable access. )
> Builder and Crystal Reports and other 'goodies', please goto:
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
We have consolidated our part classes into a more manageable number over the
last few months. We renamed the description to have the inactive classes
fall to the bottom of the sort and removed all of the associated GL account
numbers in Part Class Maintenance. However, if someone selects one of the
invalid classes by mistake the settings are somehow stored in the system and
the previously referenced GL account number, active or not, will be charged.
When I look at the account settings in the maintenance screen they are all
Thanks in advance,
Michael Benedict
IS Manager
>the last few months. ... However, if someone selects one of the invalid
>classes by mistake the settings are somehow stored in the system and the
Sounds like it is falling back to the default GL Control Accounts. Check
in Company Maintenance -> Module Config -> Control Accounts to see if those
are the numbers it's using.
>but if I create a report and include the ID, Desc and GL Expense Account
What table(s) are you reporting from?
-Wayne Cox
Twenty Three -- Information Technology Consulting
828-685-2338
We ran into this when changing our control accounts last year. If a GL account is referenced in a control account master file (e.g. Product Group, Part Class, etc.) you can inactivate this GL account without receiving an error message. However, if that product group (in this example) is used in a transaction the system will post to this inactivated account. This can cause quite a bit of confusion if you are not aware that this can occur.
Now, more specifically to your issue, the GL distributions are created at the time of the transaction. If you change the GL accounts in the master file after the transaction has occurred it will not retroactively update the original transaction. Timing is definitely critical when changing your master file control accounts.
Mike Lowe
Corporate I.S. Manager
Connor Manufacturing Services
MLowe@...
(949) 713-3328
Sent: Thu 6/5/2003 10:53 AM
Cc:
Thanks in advance,
Michael Benedict
IS Manager
<http://rd.yahoo.com/M=247865.3355058.4641699.1261774/D=egroupweb/S=1705007183:HM/A=1482387/R=0/SIG=16ng22kln/*http://ads.x10.com/?bHlhaG9vaG0xLmRhd=1054835623%3eM=247865.3355058.4641699.1261774/D=egroupweb/S=1705007183:HM/A=1482387/R=1=1054835623%3eM=247865.3355058.4641699.1261774/D=egroupweb/S=1705007183:HM/A=1482387/R=2>
<http://us.adserver.yahoo.com/l?M=247865.3355058.4641699.1261774/D=egroupmail/S=:HM/A=1482387/rand=537645573>
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Wayne/Mike
This account is not listed in any of the control accounts. I just tried
creating a dummy po and received it into the system referencing this part
class and got the same results. The report is generated from the PartClass
table. I just tried this with another class as well, I went in removed the
accounts then ran the report and the old number still shows. Not sure if it
matters, but we are on version 5.0.
Michael
> From: Mike Lowe [mailto:MLowe@...]
> Sent: Thursday, June 05, 2003 1:20 PM
> Mike Lowe
> MLowe@...
> (949) 713-3328
> Cc:
> inactive classes
> selects one of the
> in the system and
> will be charged.
> screen they are all
> and GL Expense
> reports. Has anyone
> Thanks in advance,
> Michael Benedict
> IS Manager
We were having the same problem and sometimes still do. Our problem happened
Karen Brodniak
Accounting Manager
425-742-7011 X44
Fax 425-353-8945
karen.brodniak@...
the
account
and
charged.
Thanks in advance,
Michael Benedict
IS Manager
You're running into the same problem we encountered. When you deactivate a GL account that is used in a control account it will not show in the control account maintenance screen. However, if you run a RB report on that table you will see that the inactivated GL is still associated with the master file. The only solution to this problem is to reactivate the GL account. Once you reactivate the GL account you will then be able to view it in the master file in question. You can then change it to something else. Once you've removed all the associations with the GL you will then be able to re-deactivate the GL account.
Hope this helps.
Mike
Sent: Thu 6/5/2003 11:33 AM
Cc:
Wayne/Mike
Michael
> Mike Lowe
> MLowe@...
> (949) 713-3328
> Cc:
> inactive classes
> selects one of the
> in the system and
> will be charged.
> screen they are all
> and GL Expense
> reports. Has anyone
> Thanks in advance,
> Michael Benedict
> IS Manager
ADVERTISEMENT
Click Here! <http://rd.yahoo.com/M=244522.3313099.4604523.1261774/D=egroupweb/S=1705007183:HM/A=1595054/R=0/SIG=124km4b11/*http://ashnin.com/clk/muryutaitakenattogyo?YH=3313099&yhad=1595054>
<http://us.adserver.yahoo.com/l?M=244522.3313099.4604523.1261774/D=egroupmail/S=:HM/A=1595054/rand=770164131>
Michael
> problem happened
> Karen Brodniak
> Accounting Manager
> 425-742-7011 X44
> Fax 425-353-8945
> karen.brodniak@...
> the
> inactive classes
> account
> one of the
> and
> charged.
> they are all
> Thanks in advance,
> Michael Benedict
> IS Manager
> Builder and
> enable access. )
What type of inventory transaction was generated? You didn't mention if it
was a Part Master item, and what it was received to (stock, inspection,
wip, etc) I posted a very useful spreadsheet on the yahoo site a while
back. This link might work:
http://f4.grp.yahoofs.com/v1/IIXfPgW4PGLNe0hEJqP3ADQsBSszij_F07uCA5rfNUW2XUO2zIeTOi-X0GWW8UWL5xcEzeJjnzFJr74p/Vantage%20Admin/Vantage_5_Transaction_GL_Hierarchy.xls
If not, try the link to our files section at the bottom of every message
and look under Vantage Admin for
Vantage_5_Transaction_GL_Hierarchy.xls This shows the search logic used
to determine the GL number for all Vantage transactions. Find the exact
transaction code for your PO Receipt (eg: PUR-STK, PUR-MFG) and you should
be able to track down the source of the GL number.
-Wayne Cox
828-685-2338
It is a PUR-UKN for an expense item that is not in the part master file.
Michael
> From: Wayne Cox [mailto:wmc20@...]
> Sent: Thursday, June 05, 2003 1:49 PM
> this part
> the PartClass
> mention if it
-Wayne Cox
828-685-2338
Michael
> this part
> the PartClass
> mention if it
-Wayne Cox
828-685-2338
