Part costs Blank Title 87438
Mark,
Thanks for the information. Just to let you know what I learned, if you pull the cost from the parttran table, I can get the cost breakdown at the sales level.
Thanks again, and have a great weekend.
Best,
Michelle de la Vega
Business Applications Manager
Cold Jet, LLC
455 Wards Corner Road
Loveland, Ohio 45140
USA
+1 513-716-6400 (office)
+1 513-382-3281 (mobile)
+1 513-831-1209 (fax)
www.coldjet.com<http://www.coldjet.com>
[cid:image001.jpg@...137640]
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mark Wonsil
Sent: Tuesday, February 09, 2010 9:32 PM
Subject: Re: [Vantage] Part costs
Hi Michelle,
> My boss has asked for a report that shows material costs broken down by the
> actual material, labor and burden for items that are manufactured but pulled as
> material instead of as a subassembly. Is that possible?
In the Costing Workbench, there's a check box that says, "Consider Pull as Assembly". If I recall correctly, you check it to roll up costs that way and uncheck it to see costs the other way. You can create a cost group to test it without posting.
Mark W.
Hi everyone,
My boss has asked for a report that shows material costs broken down by the actual material, labor and burden for items that are manufactured but pulled as material instead of as a subassembly. Is that possible?
So for instance, I create a job to make part ABC and the costs are as follows:
Material $10
Labor $50
Burden $100
Total $160
Then I use part ABC to make part # 123. That cost looks like this:
Material $160 (from part ABC)
Labor $40
Burden $70
Total $270
But what my boss wants to see is this:
Material $10 (from original ABC Part)
Labor $90 (ABC Labor plus 123 Labor)
Burden $170 (ABC Burden plus 123 Burden)
Total $270
Has anyone done anything like this in the past? If so could you share your ideas with me.
Thanks for all of your help!
Michelle de la Vega
Cold Jet, LLC
USA
[cid:image001.jpg@01CAA99B.372A3B20]
Hi Michelle,
Mark W.
