Part Creation Date
You could try populating one of the character## (or shortchar##) fields in Customer or Vendor to be set equal to the Integer type CustNum or VendorNum. Trigger it via a post process (BPM) or AfterMethod (client VB customization) of the Customer or Vendor BO's New method.
That would allow you to create a BAQ join to ChgLog through these char fields rather than the Cust/VendorNum fields.
To make it all neat and tidy, you'd probably want to go backfill the char field data in any existing records.
Make sense or am I missing the intent entirely?
Rob
--- On Fri, 11/28/08, Brian W, Spolarich <bspolarich@...> wrote:
Subject: Re: [Vantage] Re: Part Creation Date
Date: Friday, November 28, 2008, 3:47 PM
I have one better. All of those changelog records are stored in the
chglog table, with the primary ID of the changed record in the Key1 field
(if I recall) as a string.
So I can write a BAQ that queries for that and joins it with Part
information and generate a ³Part Change Log² report that shows just new
parts, or modified parts, etc.
However I can¹t do the same thing with the Customer or Vendor tables,
because the Key1 value stored in ChgLog is CustNum or VendorNum, and that
field is an integer in the source table and a string in the Chglog table.
The resulting BAQ returns no data because of (presumably) the type mismatch.
Is there any way around this? I¹d like to be able to provide BAQs that
show new customers, new vendors, etc. in a generic way.
-bws
On 11/26/08 12:40 PM, "Nigel Kerley" <nigel.kerley@ johnhinde. com> wrote:
> If you're just looking for the date, and don't want to use it for
> anything: we have a BAM setup against the Part table, the only field
> selected is PartNum and Create Log is ticked.
> This records the date/time that a Part is created and the User that
> created it.
> To view, we just open the Part in Part Maintenance and slect Change
> Log from the Actions menu.
Does anyone know a quick way to get the date that a part number was
entered into the system? I did not see that field in the part table or
the partdtl table. I have added a ud field that is supposed to default
to the current date on a new add but if the user duplicates a part, it
brings over the date from the original record. I am logging this
information but trying to parse the chglog table through Crystal is
terribly slow. Is there somewhere else this information may be kept?
Kersten
We have wanted this information as well but the only thing we have come up
with is turning on the logging and getting it through that.
_____
kam4085
Sent: Wednesday, November 26, 2008 11:53 AM
Subject: [Vantage] Part Creation Date
Kersten
No virus found in this incoming message.
Checked by AVG - http://www.avg.com
Version: 8.0.175 / Virus Database: 270.9.10/1810 - Release Date: 11/26/2008
8:53 AM
You could use a BPM to set the date field, part.getnewpart would be the method you want.
Sent: Wednesday, November 26, 2008 10:52:48 AM
Kersten
created it.
Nigel.
or
default
it
> Thanks
> Kersten
Kersten,
There was a lab at perspectives which did exactly as you are asking
about. The BPM Lab Part 2 Excercise one: Display Created by and date
information. The exercise talks about doing this for the ABCcode part I
walked through it and actually did it for the Part. It appears to be
working for us. I have not confirmed what date it uses when a part is
duplicated but for new parts it appears correct. I will try to test for
duplicating parts.
Jim
Of Tony Hughes
Sent: Wednesday, November 26, 2008 11:30 AM
Subject: Re: [Vantage] Part Creation Date
method you want.
From: kam4085 <kmaclennan@... <mailto:kmaclennan%40semrock.com>
Kersten
Same here: Change log.
Rob
--- On Wed, 11/26/08, Charlie Wilson <foamdesigncsw@...> wrote:
Subject: RE: [Vantage] Part Creation Date
Date: Wednesday, November 26, 2008, 12:19 PM
_____
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of
kam4085
To: vantage@yahoogroups .com
Kersten
Checked by AVG - http://www.avg com
8:53 AM
Change log is not a flexible tool for saving/tracking changes. The
biggest disadvantage is that you need to open particular record to be
able to obtain a changes for it.
Moreover - the way how 'ChangeLog' is loging data into table makes very
difficult to analyze the information.
I would suggest to create a simple BPM that can do it for you.
Grzegorz Szczepański
Dnia Wed, 26 Nov 2008 17:40:30 -0000
> created it.
> Nigel.
> or
> default
> it
> > Thanks
> > Kersten
-bws
> created it.
