Thank you. I left a VM on Thursday about the issue.
Kind Regards,
Miguel A. Santillan
ERP Administrator
Compass Components, Inc.
510-661-6666 Office
510-656-0603 Fax
msantillan@...<mailto:msantillan@...>
www.ccicms.com<http://www.ccicms.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Stephen Edginton
Sent: Thursday, January 19, 2012 3:41 PM
Subject: RE: [Vantage] Part creation in 9.05.60X - How long does it usually take,
It should take < 1-2 seconds.
There is a known bug in versions < 9.05.607 where the system performs a table scan on the JobMtl Table looking for the part to establish the unit of measure to default (in case this part was used as a purchase direct material).
New sites typically don’t see this, as they have no data or small amounts.
Converted sites with millions of Job Materials see this very quickly, I don’t have the SCR number but Epicor support should be able to help.
Regards,
Stephen Edginton (Beng) | Technical Director
Mobile: +44 7734 858 415
DDI: +44 121 314 1179
Main: +44 121 314 1170
Dot Net IT Limited, One St Kenelm Court, Steel Park Road, Halesowen, B62 8HD, United Kingdom.
This e-mail and any files transmitted with it are confidential and are intended solely for the use of the intended recipient(s). If you are not the intended recipient, you must not copy, distribute or take any action based on this communication. If you have received this communication in error please contact StephenE@...<mailto:StephenE%40dotnetit.co.uk><mailto:StephenE@...<mailto:StephenE%40dotnetit.co.uk>> and delete this communication and any copies of it. Any views or opinions presented are soley of those of the author and do not necessarily represent those of Dot Net IT Limited.
Dot Net IT Limited, Reg No 4412519
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of miguel_ccicms
Sent: 19 January 2012 22:46
Subject: [Vantage] Part creation in 9.05.60X - How long does it usually take,
I am curious how long it takes for other companies to create a new part.
It is currently taking about 18secs to 20secs so that my spinning wheel stops. I turned off all my BPMs and have 56636 part numbers in the system. I also have done this when no users are on as well.
Your input would be appreciated.
Kind Regards,
Miguel A. Santillan
ERP Administrator
510-661-6666 Office
510-656-0603 Fax
Regards,
