Part Demand but MRP not flagged - how does system acknowledge a job is needed to fulfill demand
Hi all, new to Epicor and looking for assistance in understanding if there is an active part and it does not have Process MRP selected, where in the Epicor system can you manage demand for this part to create jobs, etc. Our issue is that we intend for Process MRP to be selected, but there have been a handful of times, for some reason unknown, it is not selected. Once demand hits the part, of course MRP does not process a job so we are looking for a safety net to catch these items. We have been ERP trained to utilize MRP to manage jobs and we use Planning Workbench to catch items that MRP cannot process. But these items do not hit Planning Workbench because they are not running through MRP to begin with. I am hopeful/and pretty sure there is an easy answer to this and it is just out lack of Epicor planning knowledge to know where to look. Thanks in advance for responses!
(Sorry… I got ahead of myself… read my second post first :rofl:)
The easiest is probably to create a BAQ against the PartDtl table. This is the table that tracks individual part demand.
You’ll want columns like:
Type - This tells you if the demand is a Material or subcontract.
PartNum
RequirementFlag - tells you if this record is a receipt or a requirement.
Qty
OrderNum
OrderLine
OrderRelNum
You can also use table criteria on PartDtl where Type <> sub (to rule out subcontract) AND RequirementFlag = true.
You can also include Job and PO columns to see if a particular demand is already on a job, or included on a PO… what you’re looking for is a part demand (requirement) that ISN’T linked to a job or PO yet. So, your query can include logic for where PONum, POLine = ‘’ and/or JobNum/AssemblySeq = ‘’
You could also link the Part table to PartDtl to grab information (or filter out resutls), for example, if the PartNum is a manufactured part or a purchased part.
For your particular case… you can filter for where Part.ProcessMRP = false.
This would easily filter the list to only parts that MRP is going to skip over.
That’s where I would start.
Once you identify a manufacturing part that has demand, but doesn’t yet have a job… you can create the job manually.
If the part is on a Sales Order, you can use the Order Job Wizard to create a job from Sales Order Entry if you wish.
As an example… I have a BAQ (which I then built a dashboard around) to track parts that didn’t result in PO Suggestions. So it runs a series of queries against PartDtl (and other tables) to find parts with Sales Order or Job Mat’l demand… but did NOT have linked PO suggestions. I also added whether these parts were linked to open RFQs because, for purchased parts, this is one of the black holes in Epicor. If you process a suggestion and create an RFQ… the demand is still in the system… the suggestion goes away… and there’s no other way to know if anybody is working on that material or not.
Oh, I forgot to mention you may want to explore the Planning Workbench.
This could be your out-of-the-box monitor. I think it is independent of MRP. Planning Workbench (I believe) monitors the PartDtl table and looks for part demand records.
I think you can also kick off jobs directly from the Planning Workbench.
Apologies I didn’t mention this first. This should probably be your best “out-of-the-box” resource already baked in to Epicor.
The custom BAQ and dashboard (using PartDtl) would be if you need something more tailored to a specific purpose.
To extend on what @dcamlin recommends, after MRP completes you need to run the Production Planning Process that will then populate the Planning Workbench.
Another simple alternative would be to create a Data Directive on the part table and force the MRP checkbox to true when the part is created. This way you get the native benefits of MRP processing and overcome the omission of the Process MRP flag not being set.
@bswearengin If every part is being run through MRP, wouldn’t that slow the process down? Granted you can always go and uncheck the box afterwards to revert the default.
Starting with 2025.1 they have rewritten the MRP engine so it runs in under an hour. Many of the needs like Regen vs Net Change were based on the old slow times. If you have 100k parts and 10k open orders and jobs it may take longer. But, that would be a very big shop.
Thanks David, we use Planning Workbench daily. Our Process MRP is ran nightly and unfortunately these parts that do not have Process MRP do not show on the Planning Workbench, so it is our assumption this is because the Planning Workbench works with the MRP process and only populates items MRP could not create jobs for. It would skip over any part that does not have this flag selected, correct? So, it would not be included on the Workbench? We would love to know if our thought process is incorrect and the reasoning for them not populating on the Planning Workbench is possibly another reason and not related ot the Process MRP flag :slight_smile: .
Thanks Bob, we are working towards future solutions to ensure the box is selected on all parts. Just was unsure if somewhere in Epicor these parts would be visible (like a workbench or report) to show jobs required because there is demand. They are falling through the cracks and we are surprised there is not somewhere to view them, especially because not everyone uses MRP in Epicor from what I’ve heard, but we are so new to the game and use MRP that we’ve never learned the planning logic when not using MRP to process supply needs.
It is my understanding that the Planning Workbench is not tied to running MRP and should not be directly tied to the parts having ProcessMRP = true. But, yes, I could be wrong about that.
The application help even states:
If your company uses the Material Requirements Planning (MRP) module, the application can also create suggestions not linked to sales orders. For more information on this functionality, review the Material Requirements Planning article.
This again makes me believe MRP is not a requirement… but if you DO use MRP, you can also get additional suggestions.
On the pesky parts… you state that there is existing demand. What is the demand type for these parts? Is the demand a job material? So, you need to make Part A so it can be used in the production of Part B? OR… is the demand that the part is an existing line item on a sales order, so there is “demand” for the part?
I ask because one potential hole these parts could fall through is if a Sales Order Line is for a part that is not set up to be processed by MRP… AND the Sales Order > Line > Release is not flagged as Make Direct… the system may not recognize that demand.
For example, you could have a part that is ProcessMRP = false…
If that part is also recorded as Non-Stock = false… the system is thinking this is an inventoried part… any sales order line item created for this part is going to be fulfilled from inventory… it will NOT default the sales order release to Make Direct.
So although the sales order creates “demand” for the inventory, it may not create the direct manufacturing demand/job suggestion that would cause the part to appear in Planning Workbench. And with ProcessMRP = false, MRP isn’t going to step in and plan replenishment of that inventory demand either.
Could be one scenario where a manufactured part could potentially fall through the cracks.
I would test this out… if one of the troublesome parts is on a Sales Order, and it is not “Make Direct” on the release… set it to Make Direct. Then go into/refresh Planning Workbench and see if that part shows up.
We created a BAQ to show us active part numbers where Process MRP is unchecked. This is set up as a dashboard our planner has on her home page: it should always be empty. If she sees something pop up in the dashboard when she logs in, she knows a part was set up incorrectly and needs to be fixed. She can then either run MRP specifically for that part or manually check it for demand.
I agree that Process MRP on MOST parts should probably be the default… but there are cases where you don’t want parts processed. For example non-Quantity Bearing parts (expense items). MRP doesn’t need to monitor and plan for toilet paper and coffee filters. Yes, we have part numbers in our system for these types of items because it makes it easier for our buyers to look them up and create POs to buy from a bulk supplier… but we don’t inventory these parts and MRP has no reason to be burdened by looking at them.
But… agreed that a BAQ/Dashboard (which can easily filter out parts where QuantityBearing = false… or other custom scenarios) is a good safety net.
