Part description search
Did you run a couple of the script files to create the indexes?
the mfgsys803\Server\sql folder has some scripts in there that you load into query analyzer. Make sure your drive path matches what they programmed though. I think they use drive E: where mine was G:. I would drop all the full text indexes you have, then recreate them with the FullTextCreate.SQL script. As long as your path is correct in that script you shouldn't get any errors. Then you can populate them by going to SQL Explorer and right clicking full text indexing then clicking populate. Also MfgTest803 is different from MfgSys803 as far as creating the indexing. Make sure you adjust the script accordingly based upon what DB you are using it for.
----- Original Message ----
Sent: Monday, April 21, 2008 11:46:41 AM
Subject: [Vantage] part description search
Running Vantage 803.305D. On SQL 2000
In the Part Search, under section 'Where part Description contains' I'm getting an Error. Support claims that I need to do Full-text Catalog. I have rebuilt all Catalogs and repopulated all catalogs with same results. Anyone out there with the same issues or any ideas to fix?
Thanks for all your responses.
Ken
____________ _________ _________ _________ _________ _________ _
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile. yahoo.com/ ;_ylt=Ahu06i62sR 8HDtDypao8Wcj9tA cJ
____________________________________________________________________________________
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Ken
