Part Entry Date
We wanted the same thing, we put a bpm in place to populate a date field.
Rob Bucek
Production Control Manager
D&S Manafacturing
M: (715) 896-0590<tel:7158960590>
P: (715) 896-0590<tel:7158960590>
Sent from my Verizon Wireless Droid
-----Original message-----
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Fri, May 25, 2012 02:31:26 GMT+00:00
Subject: Re: [Vantage] Part Entry Date
Change log is the only thing I know for sure Notes Date, time, userID & initial value. You'd want to enable logging on a Part field (or several that are of interest to you) as it is established before PartPlant. Weakness is the log file is lost if the record is deleted (unless you write a process to archive & retain it in near real time).
On Thu, May 24, 2012 5:24 PM EDT swenson.justin wrote:
>Is there a way to view the exact date and time that a part was entered into the system?
>I looked at PartTran for a specific transaction type related to entry. I also unsuccessfully looked at connecting SysTag to PartTran and Part. I was hoping to use the CreatedOn and CreatedBy fields in that table.
>Thanks,
>Justin
Justin
The only way I track the part create date is by turning on change logs.
Part table PartNum field.
It might help you going forward, no history though.
> Thanks,
> Justin
>Thanks,
>Justin
