Part Import very Slow
Hi Bruce,
> We have a Progress db and used Pervasive and ODBC to import about
> 25,000 parts. It took about 25 minutes.
There's no doubt that the Pervasive tool is very fast. The trouble with the
tool is that it bypasses all business logic. So if you're not careful, you
can mess up your database. I believe that more than one person on this list
ended up with NULL fields that caused trouble later on - and that was even
after using the templates that Epicor had sold them.
That's not to say that a quality issue in the business object won't cause
trouble too but it will catch more errors.
Mark W.
Hello,
We have several parts that need to be imported into vantage (17000) . We are
doing it Via SC using a work flow. It calls the PartServices webservice we
done the connections and it works ok. Except that at the rate its going 1-5
seconds per part. It would take several days if not weeks to get these on
there. I thought it was SC being slow so we wrote our own procedure and
interact directly with the web services using WSE 3 and C# but it takes
about the same time to do the imports. Is this normal? If not then would the
problem be on IIS or the App server. The system seems to degrade overtime as
we import more and more parts.
Any ideas would be extremely appreciated
Sincerely
Jose C Gomez
http://www.josecgomez.com
FYI
Microsoft and AOL won't give you money for forwarding an email.
The little girl named ____ is NOT dying of cancer.
And you will NOT die or have bad luck if you don't forward a message.
Wouldn't 17,000 take less than a day at that rate? Do you mean 170,000?
----- Original Message -----
Sent: Monday, February 09, 2009 2:26 PM
Subject: [Vantage] Part Import very Slow
Hello,
Sincerely
Jose C Gomez
FYI
1000-2000 parts/hour is fairly typical. The rate-limiter are the web
services - there's just a lot of overhead involved with the protocol
(SOAP). Service Connect will process things as quickly as the web
services will turn them around.
Epicor's position has consistently been with us that the web services
are slow but included with the product. If you want high-performance
data imports then you need to buy Pervasive. I have no argument with
that model.
You could easily break up your data import into multiple sub-files and
submit them in parallel. That should give you better throughput. I
imported 2347 parts this morning though and it took a couple of hours.
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
Picometrix
bspolarich@... ~ 734-864-5618 ~
www.advancedphotonix.com
Of Jose Gomez
Sent: Monday, February 09, 2009 3:27 PM
Hello,
are
we
1-5
on
the
overtime as
Sincerely
Jose C Gomez
FYI
1-5 seconds per part is normal.
I just imported 45,000 parts that way over New Years weekend. It took 3
days for the import in 2,000-part sets. Painful and frustrating.
I did an import directly into SQL and I did 1,000+ per minute.
And yes, you will need to restart Service Connect services every 10,000
parts or so. I cleared my Service Connect messages/logs every 2000 part
set I imported.
Of Jose Gomez
Hello,
are
we
1-5
on
the
overtime as
Sincerely
Jose C Gomez
FYI
How lovely importing all our inventory will take weeks at this rate.
Thanks for your input.
Sincerely
Jose C Gomez
FYI
> set I imported.
> From: vantage@yahoogroups.com <vantage%40yahoogroups.com> [mailto:
> vantage@yahoogroups.com <vantage%40yahoogroups.com>] On Behalf
> Of Jose Gomez
> To: vantage@yahoogroups.com <vantage%40yahoogroups.com>
> Hello,
> are
> we
> 1-5
> on
> the
> overtime as
> Thanks
> Sincerely
> Jose C Gomez
> FYI
I hear you. If there is any silver lining to this scenario, at least
you don't need exclusive access to the database. Meaning you can do it
during normal business hours just fine.
Of Jose Gomez
Sent: Monday, February 09, 2009 5:21 PM
Subject: Re: [Vantage] Part Import very Slow
Sincerely
Jose C Gomez
FYI
3
10,000
part
> set I imported.
> Of Jose Gomez
> Hello,
We
> are
webservice
> we
going
> 1-5
> on
and
takes
would
> the
> overtime as
> Thanks
> Sincerely
> Jose C Gomez
> FYI
There is a third option and that is adding your parts using the business
objects directly using C# or VB.Net. This is how I did it. You eliminate the
all of that marshalling and un-marshalling overhead of SOAP. You can get the
idea from a previous thread:
http://tech.groups.yahoo.com/group/vantage/message/60826
Mark W.
Mark, would you be willing to post a more complete example somewhere?
I'm well-versed in C#/.NET, and I'm wondering how one gets started
with programming against the .NET APIs. Did you buy the SDK or is there
a cheaper, simpler way to consume these without having to become a total
expert?
-bws
Picometrix
Of Mark Wonsil
Sent: Monday, February 09, 2009 9:13 PM
Subject: RE: [Vantage] Part Import very Slow
the
the
Mark W.
I would like that also a more in depth example if you are willing we do a
lot with C# .NET here and this would be awesome to implement and it seems it
would cut down our import time tremendously.
Thnaks
Sincerely
Jose C Gomez
FYI
On Tue, Feb 10, 2009 at 9:14 AM, Brian W. Spolarich <
> expert?
> -bws
> Picometrix
> bspolarich@... <bspolarich%40advancedphotonix.com> ~
> 734-864-5618 ~
> Of Mark Wonsil
> the
> the
> Mark W.
Jose after Brian,
> it would cut down our import time tremendously.
> > expert?
Really, all I did was to open a Project (you can even do this is the Express
Editions of VS for C# or VB.Net) and add the references to the business
objects that I wanted to work with: Epicor.Mfg.IF.Part.dll,
Epicor.Mfg.AD.Part.dll, etc.
Next, I did the same kind of tracing analysis that you would do for SC to
see the business objects and parameters used. The calls should be similar to
SC.
Basically, you consume a full license and log in (Session object) as if you
were the UI and the BOs don't really know that you're not the UI (or it
shouldn't if the sales rep was telling the truth about the separation of the
UI to the business logic. The code will (or should anyway) throw exceptions
if you do anything wrong.
Adding parts with plant and rev records is quite easy. OTOH, methods of
manufacturing are a real b_tch since you have to control the Engineering WB
business object.
I have to run out for a bit but ask if you have any questions about the
previous example post
(http://tech.groups.yahoo.com/group/vantage/message/60826) or if there's
something else that you're trying to do.
Mark W.
Thanks Mark,
Do you need the SDK for this to work? We didn't purchase that and I am not
sure if it would work without it.
Thanks again.
Sincerely
Jose C Gomez
FYI
On Tue, Feb 10, 2009 at 10:15 AM, Mark Wonsil <mark_wonsil@...> wrote:
> Jose after Brian,
> total
> > > expert?
> Express
> to
> SC.
> the
> business object.
> Mark W.
Hey Mark,
We are having a little difficulty in finding the object
"Epicor.Mfg.BO.PartDataSet". Can you tell us where you got that
from???
--Matt
Of Mark Wonsil
Sent: Monday, February 09, 2009 8:13 PM
the
the
Mark W.
We use it for all out integration needs although it is very slow and cranky
LoL.
Sincerely
Jose C Gomez
FYI
On Tue, Feb 10, 2009 at 11:27 AM, Bruce Ordway <cooner_55421@...>wrote:
> Hi,
> We also have Service Connect, but I have not learnded to use it yet.
> I have Pervasive & there has been no need for anything else yet.
> I have been hearing more about Service Connect though & am wondering
> if I should start working with it. Any suggestions for somebody just
> starting out with it? What are some of your favorite things to use it
> for?
> Thanks,
> Bruce
> --- In vantage@yahoogroups.com <vantage%40yahoogroups.com>, "Vic Drecchio"
> <vic.drecchio@...>
> took 3
> 10,000
> part
> > set I imported.
> Behalf
> > Of Jose Gomez
> > Hello,
> (17000) . We
> > are
> webservice
> > we
> going
> > 1-5
> these
> > on
> and
> takes
> would
> > the
> > overtime as
> > Thanks
> > Sincerely
> > Jose C Gomez
> > FYI
> message.
> must
> access. )
> Builder
> from???
Make sure that you add a reference to Epicor.Mfg.BO.Part.dll (you should
have the Vantage/Epicor client on your machine and browse to the client
folder) It's in there. Once you add the reference to the project, you can
use the Object Browser to see the properties and methods and even *some*
documentation!
Mark W.
