Part Location tags
Is the a place in Kinetic to print a part tag label? So basically a label that will give the part location to place them on the shelf.
There should be an option to print a tag during receipt transactions. Those tags should pull the bin from the current transaction. If you’ve set up primary bin locations for your parts, the transaction will default to that.
yes, we do print the receipt part tags. This is a tag or label to create for new bins (locations)
Run a query on the WhseBin table and embed it in a SSRS report. Then format it to print out the bin designation and maybe a barcode on a label-sized output.
FWIW, I never had the patience to set this up in Epicor for my users.
I’ve made many labels for Epicor use, just not for shelves.
And I’ve made shelf labels, just not for Epicor use.
It’s a super-easy task to do in BarTender or whatever label software you like, that it’s like the one thing that the users can actually do themselves.
And in theory, they aren’t putting up shelves daily. (Right? :face_with_raised_eyebrow: ) So I never saw the reason to customize Epicor for it.
i agree with you but we created one in Epicor. UGh.
