I seem to remember the 3111ESC code example using an EpiViewNotification trigger (and you are right - it often doesn't seem to work for simple tasks like this where it 'should').
Try a different event trigger...Perhaps AfterAdapterMethod with some logic to only actually set the Part.NonStock value to True if a new Part record has just been created.
If all your Parts are always non-stock, just take the easy road and set the field everytime the FormLoads.
Rob Brown
setrumbo <strumbo@...> wrote:
Thank you Peter for the response ...
I had already found the document on EpicWeb and it does not work for
my installation. I have called customer support but they have nothing
yet to tell me. I put some message boxes into the code to make sure
the event was triggering but I never get the addrow notification.
Still waiting on support or someone, I've done everything I know.
Steve
Rob Brown
Steve
--- In vantage@yahoogroups.com, "pvolkert365" <pvolkert@...> wrote:
> There is a document 3111ESC that is available. We originally got it
> from Support. It is available on EpicWeb. We were wanting to do the
> same thing you are. We used those instructions and they worked fine.
> Peter
> --- In vantage@yahoogroups.com, "setrumbo" <strumbo@> wrote:
> > I am new to Vantage and have been asked to customize the part
> > maintenance form so the NonStock check box is marked by default for
> > every new part entered into the system. I am using 8.03.11b if that
> > makes any difference. Epicor has a walk through on this on epicweb,
> > but it does not work. Does anyone here know how I can do this?
> > This is my first customization and it seems like it should be simple
> > enough. Does anyone here do any customization?
> > Thanks for any help I get....
Looking for last minute shopping deals? Find them fast with Yahoo! Search.
