Can someone tell me what report works best for part profitability? Again, I’m new to this program and company and I want to get information on profitability and I’m not finding what I need.
Thank you
Thank you
I’m fairly certain there was an out of the box Gross Margin report in Financial under AR Reporting.
From what I’m seeing with running that report is appears to be using estimated cost not actual cost. I’m looking for something that uses actual cost.
The InvcDtl table has price and the 5 cost buckets of “actual” cost. Note that this value is using the cost method if pulled from stock, but the actual if shipped from a job.
Thanks for your response - I will see if I can pull together a report for what we need.
