Ed
Just try leaving the line as it is and changing the part numbers to the
correct ones
Then receive back in.
Gary
Of Ed Garbowski
Sent: 07 May 2009 15:49
Subject: [Vantage] Part receipt problem
The wrong part numbers were used on a PO and then received using those
wrong part numbers. The error was recognized while they were in
inspection and the receipt lines were deleted, thereby removing them
from inspection. The correct part numbers were added to the PO with the
intent to re-receive the parts using the right part numbers.
Now Vantage will not allow the PO line quantities of the wrong part
numbers to be changed to zero (understandable) and will not allow those
lines to be deleted from the PO either due to the original received Lot
still showing in the system with zero quantity.
What is the proper way to straighten out this part receipt problem?
Ed
correct ones
Gary
Of Ed Garbowski
Ed
