I got it knocked out thanks for the help!
~Charlie
________________________________________
bw2868bond
Sent: Tuesday, February 24, 2009 7:52 PM
Subject: [Vantage] Re: Part Rev SC
Using the BL Tester tool, I did a GetByID then GetNewPartRev which
made a 'copy' of the existing part rev, with one big difference. The
RowMod of the new partrev has a value of 'A' When you invoke the
Update method, only the record with the 'A' will be updated...
--- In vantage@yahoogroups.com, "Charlie Wilson" <foamdesigncsw@...>
wrote:
~Charlie
bw2868bond
wrote:
>not the
> Basically where I'm getting shafted is the conversion between
> getnewpartrevresponce and updaterequest.
> I can't figure out how to have my data end up in the new record and
> pre-existing revision record so that when my update runs it leavesthe
> pre-exsisting record under partrev alone and modifies the new oneso that it
> contains the values I want.Behalf Of
> And ideas
> ~Charlie
> Charlie Wilsonactually
> Sent: Tuesday, February 24, 2009 6:29 PM
> Subject: RE: [Vantage] Re: Part Rev SC
> Sure did.
> GetbyID
> GetNewPartRev
> Update
> I now have it running with out any errors but now it does not
> create the alt method. I don't know if this is progress or notÂ…Behalf Of
> ~Charlie
> bw2868bondthat
> Sent: Tuesday, February 24, 2009 5:44 PM
> I have heard the only silly question is the one not asked...
> Are alt methods created using part maintenance?
> Have you traced the creation of an alt method using the Vantage UI
> apps and then modelled your SC along that process?
> Just trying to help...
> bw
> --- In vantage@yahoogroups.com, "Charlie Wilson" <foamdesigncsw@>
> wrote:
> > Yep that is what I think too but why isn't it populating.
> > ~Charlie
> > _____
> Behalf Of
> > Mark Wonsil
> > Sent: Tuesday, February 24, 2009 5:17 PM
> > Subject: RE: [Vantage] Part Rev SC
> > Hi Charlie,
> > 'Company, PartNum, RevisionNum, AltMethod' is constrained to be
> unique.
> > Value 'FDI, SEL-11018171, 3010-01REV15, ' is already present.;
> > ^ ^ ^ ^AltMethod
> > ^ ^ ^Rev
> > ^ ^Part
> > ^Company
> > This seems to indicate that the Rev already exists. It appears
> you'resince
> > not assigning (or SC isn't passing) the AltMethod to the call
> it looks
> > blank for the call. Usually, the AltMethod is non-blank for
> alternate
> > methods.
> > Mark W.
> > No virus found in this incoming message.
> > Checked by AVG - www.avg.com
> > Version: 8.0.237 / Virus Database: 270.11.3/1967 - Release Date:
> 02/24/09
> > 13:35:00
