Part revision approvals
We have alternate methods for almost all of our assemblies. As far as I
know there is no way to approve an alternate method without approving the
normal method or vise versa. This will become evident when you check out a
part in engineering workbench i.e. you must check out both methods. Also,
you cannot check the part back in without approving both methods. I agree
the table layout appears that it would be possible to do otherwise but the
application does not support it. As far as us, I have never had a request
to do otherwise so it is a non-issue for us.
_____
jahatcher43
Sent: Tuesday, March 04, 2008 9:52 AM
Subject: [Vantage] Part revision approvals
We are on Vantage 8.03.404.
I'm seeking input on the behaviour of approvals when a revision has
alternate methods.
Each alternate method appears to have its own approval flag (PartRev
table) but the application appears to be enforcing approval of all
methods for a revision or none.
Does anyone know if it is possible to manage the approvals of methods
individually within a revision?
alternate methods.
