I made an SSRS report of an updatable BAQ. In the BAQ report designer I added two fields as filters (part and Group). While looking at the filtered fields I noticed I could only see Active parts.
How can I also load in inactive parts?
Have you looked at Quick Search or BAQ search capability?
I think you will find that the default for part status is Active and if you select the drop down it should show ALL, Active and InActive
I have not. I will check it out.
In this case the Status is greyed out. I will not give me the dropdown.
What happens when you open part entry and click the part button, is the status field greyed out there?
