One off fix the locking issue or one off fix the method/bpm problem. Hmmm
choices choices choices.
~Charlie
_____
cmulford_66
Sent: Monday, February 08, 2010 3:15 PM
Subject: [Vantage] Re: Part.Update Method BPM Issues 8.03.408
There's is a 'one off' fix for the labor lock issue. Be sure to get the
second one as the first did not correct the issue. I've had no issues since
installing it over 30 day ago.
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Charlie
Wilson" <foamdesigncsw@...> wrote:
Behalf Of
~Charlie
_____
cmulford_66
>issue
> Thanks for the note. We are only going to 408 at this point due to the
> in labor with it locking up. Which apparently isn't fixed in 408B.[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
> ~Charlie
> _____
> From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Behalf Of
> Steve_Elot
> Sent: Friday, February 05, 2010 4:56 PM
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> Subject: RE: [Vantage] Part.Update Method BPM Issues 8.03.408
> Charlie,
> I had a similar problem with BPM for the part table. I think it was the
> tracking was moved to another location but the BPM for the part did notin
> update so it could not find the lot information. I can not find the exact
> step to fix but you can contact support and they should have the steps to
> fix your problem. I had to replace the BpMethod.r and CustomBOGenerator.r
> version 408, but they should have been released in patch 408A and 408B. I(5445)
> also had to delete the part.p file possible reference scr 56762.
> Steve
> -----Original Message-----
> From: Charlie Wilson [mailto:foamdesigncsw@
> <mailto:foamdesigncsw%40yahoo.com> yahoo.com]
> Sent: Friday, February 05, 2010 3:41 PM
> Yah 407 everything was flawless there put on the 408 patch and they are
> broke.
> ~Charlie
> _____
> Behalf Of
> Steve_E
> Sent: Friday, February 05, 2010 4:37 PM
> Charlie,
> Did you upgrade from an earlier version that had BPM setup?
> Steve
> Sent: Friday, February 05, 2010 3:07 PM
> Subject: [Vantage] Part.Update Method BPM Issues 8.03.408
> All,
> We are testing 408 and I have found that I can not turn compatibility back
> on for the BPMs I have on the Part.Update method. Nor can I delete them or
> disable them.
> It keeps throwing this error at me.
> Exception caught in: Epicor.Mfg.BO.BpMethod
> Error Detail
> Message: Compilation error: TEMP TABLE ttPartLot could not be found.
> ** Could not understand line 175. (196)[Non-text portions of this message have been removed]
> Type: Error
> Program: Bpm/Misc.p
> Method: DeployProcedure
> Table:
> Row:
> Field:
> Stack Trace
> at Epicor.Mfg.Proxy.BpMethodImpl.Update(BpMethodDataSet ds)
> at Epicor.Mfg.UI.Adapters.BpMethodAdapter.Update()
> at Epicor.Mfg.UI.App.BpMethodEntry.Transaction.adapterUpdate()
> at Epicor.Mfg.UI.FrameWork.EpiMultiViewTransaction.Update()
> ~Charlie
