Part with Serial Number help
Yes I do have that option...ok I will try it here. Thanks for the
reminder!
M. Manasa Reddy
manasa@... <mailto:manasa@...>
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Of Snake
Sent: Wednesday, January 27, 2010 2:18 PM
Subject: [Vantage] Re: Part with Serial Number help
Manasa,
It's been awhile since I looked at Vista so please bear with me. Under
Inventory Management - Setup - do you have a menu option Serial Number?
You may be able to create the Serial Numbers for these items. You could
also possible add these items through Quantity Adjustment and you should
be prompted for the Serial Numbers. Not sure if you would be able to do
a negative Quantity Adjsutment to remove those items that don't have
Serial Numbers. You may need to call Vista Support to clear those. I am
unable to duplicate and/or test this scenario.
Sincerely,
Stephen Schaefer
Abrams Airborne
"Manasa Reddy" <manasa@...> wrote:
> Ok, when we did our physical inventory I managed to add 3 parts
without
> serial number which actually needed serial numbers. Managed to do this
> through cycle counting.
> So what does one do to get those 3 out.
> I am on vista 8.0.812.
> M. Manasa Reddy
> Information Technology Manager
> Welding Company of America
> 800.852.2325
> 630.806.2000 ofc
> 630.806.2001 fax
> constant innovation
> www.weldcoa.com <http://www.weldcoa.com/ <http://www.weldcoa.com/> >
Ok, when we did our physical inventory I managed to add 3 parts without
M. Manasa Reddy
800.852.2325
630.806.2000 ofc
630.806.2001 fax
constant innovation
www.weldcoa.com <http://www.weldcoa.com/>
Manasa,
It's been awhile since I looked at Vista so please bear with me. Under Inventory Management - Setup - do you have a menu option Serial Number? You may be able to create the Serial Numbers for these items. You could also possible add these items through Quantity Adjustment and you should be prompted for the Serial Numbers. Not sure if you would be able to do a negative Quantity Adjsutment to remove those items that don't have Serial Numbers. You may need to call Vista Support to clear those. I am unable to duplicate and/or test this scenario.
Sincerely,
Stephen Schaefer
Abrams Airborne
> M. Manasa Reddy
> 800.852.2325
> 630.806.2000 ofc
> 630.806.2001 fax
> constant innovation
