PartCost - Last Costs
#ygrps-yiv-152232775 p.ygrps-yiv-152232775MsoListParagraph, #ygrps-yiv-152232775 li.ygrps-yiv-152232775MsoListParagraph, #ygrps-yiv-152232775 div.ygrps-yiv-152232775MsoListParagraph {
margin-top:0in;margin-right:0in;margin-bottom:0in;margin-left:.5in;margin-bottom:.0001pt;}
#ygrps-yiv-152232775 p.ygrps-yiv-152232775MsoNormal, #ygrps-yiv-152232775 li.ygrps-yiv-152232775MsoNormal, #ygrps-yiv-152232775 div.ygrps-yiv-152232775MsoNormal {
margin:0in;margin-bottom:.0001pt;}
#ygrps-yiv-152232775 p.ygrps-yiv-152232775MsoListParagraphCxSpFirst, #ygrps-yiv-152232775 li.ygrps-yiv-152232775MsoListParagraphCxSpFirst, #ygrps-yiv-152232775 div.ygrps-yiv-152232775MsoListParagraphCxSpFirst,
#ygrps-yiv-152232775 p.ygrps-yiv-152232775MsoListParagraphCxSpMiddle, #ygrps-yiv-152232775 li.ygrps-yiv-152232775MsoListParagraphCxSpMiddle, #ygrps-yiv-152232775 div.ygrps-yiv-152232775MsoListParagraphCxSpMiddle,
#ygrps-yiv-152232775 p.ygrps-yiv-152232775MsoListParagraphCxSpLast, #ygrps-yiv-152232775 li.ygrps-yiv-152232775MsoListParagraphCxSpLast, #ygrps-yiv-152232775 div.ygrps-yiv-152232775MsoListParagraphCxSpLast {
margin-top:0in;margin-right:0in;margin-bottom:0in;margin-left:.5in;margin-bottom:.0001pt;line-height:115%;}
Because the shipment doesn't pass through inventory, the costs would not be updated. Same with a purchased part bought directly to a job.
Sent: â€ŽFriday‎, ‎February‎ ‎28‎, ‎2014 ‎12‎:‎03‎ ‎PM
To: vantage@yahoogroups.com
Thanks Cathy.
costing is Lot FIFO, so I don’t think there be any harm in updating last also? Just to make it easier to find in part Tracker.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Cathy
Sent: Friday, February 28, 2014 12:49 PM
Subject: RE: [Vantage] PartCost - Last Costs
If you ship MFG-CUS – it does not update the PartCost table.
It goes to Cost of Sales or however you set up your Product Group.
You can see the cost on the Sales Gross Margin Report.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Greg Payne
Sent: Friday, February 28, 2014 9:38 AM
Subject: [Vantage] PartCost - Last Costs
905.702A SQL
I am finding that the Last Costs are updated if we do a Mfg Receipt to Inventory, but not if we Ship from the Job. MFG-CUS.
Reading the field help this seems on purpose and support doesn’t know if this is correct or not.
Is cost only updated if the transaction involves inventory?
has anyone done a DD bpm on parttran to update partcost or would you approach it differently?
Greg Payne
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
905.702A SQL
Greg Payne
905.702A SQL
Greg Payne
Thanks Cathy.
905.702A SQL
Greg Payne
We are FIFO with lot tracking and I haven't seen any use for last cost since you apply material cost to the lot itself. In what instance would you have an additional cost for manufacturing that wouldn't be tied to inventory, labor or subcontracted operation? As needed, we've modify material burden rate at the job cost adjustment level but beyond that, I don't know what/why we would need something like a miscellaneous charge
We use last cost to see changes in the unit cost of a part vs our  average cost.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of aj.rembert@...
Sent: Saturday, March 01, 2014 4:26 AM
Subject: [Vantage] RE: PartCost - Last Costs
