PartDtl Requirement Discrepancy
I am using the PartDtl table to create a manufacturing multi part time phase dashboard. There are a few issues that arise. I am using the RequirementFlag in PartDtl to determine the Demand and Supply of a parts (equivalent to sum(pending requirements) and sum(pending receipts). An issue is that a job and quantity can be marked as both a receipt and a requirement in PartDtl. For example, in time phase this part has a SO with a requirement of 6 and a job that is making 295 to stock leaving the projected balance at 487.
In my BAQ it is counting both the SO and Job in Demand (RequirementFlag = 1) and then the Job again in Supply (RequirementFlag = 0). This gives a Demand of 301 which instead should be 6. The Supply is right at 295. This then affects further calculations.
I made a simpler BAQ to find this result.
How is it possible that this job is being counted as both a Requirement and Receipt in PartDtl and how can I work around this?
I am also having issues where closed jobs are being included in PartDtl. Why is this occurring?
Have you looked in the data dictionary for this table? There are a few criteria for what the lines actually mean. See PartDtl.SourceFile especially. Also its relationships with the PartSug table
SourceFile was helpful here. Thanks! Looks like JO (JobOper) was being counted as a requirement where as JH (JobHead) was the receipt for the same job. I just filtered SourceFile <> JO in the demand subquery and it seems to have fixed the calculation issues.
