PartMtl Search Adapter
Here is some code to invoke a Part Rev search and run the BomSearch
upon selection of a part/revision: (not tested)
Private Sub btnAssemblySearch_Click(ByVal Sender As Object,
ByVal Args As System.EventArgs) Handles btnAssemblySearch.Click
'// ** Place Event Handling Code Here **
Dim recordSelected As Boolean
Dim dsSearch As DataSet = SearchFunctions.listLookup
(oTrans, "PartRevSearchAdapter", recordSelected, True, "", False)
If recordSelected
Dim adBom As BomSeachAdapter = New BomSearchAdapter
(oTrans)
adBOM.BOConnect()
Dim dsLoaded as Boolean = adBOM.GetDatasetForTree
(dsSearch.Tables(0).Rows(0)("PartNum"), dsSearch.Tables(0).Rows(0)
("RevisionNum"), "", True, System.DateTime.Now, True)
'// all of the components will now be in the
adBom.BomSearchData.PartMtl dataset - you could bind to ultragrid or
loop through the rows to do what you want.
End If
End If
End Sub
--- In vantage@yahoogroups.com, "Daniel Laidig" <daniellaidig@...>
wrote:
> Thanks, that's very useful.
> Daniel
> _____
Behalf Of
> bw2868bond
> Sent: Tuesday, July 29, 2008 9:51 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: PartMtl Search Adapter
> You will not be able to use the list lookup function for that
adapter.
> If you have installed the BL Tester tool, try using the
> Epicor.Mfg.BO.BomSearch.dll to see what parameters it requires, and
> if it returns the data you are looking for.
> If you havent installed the tool, it should be located under the
> utilities folder \\<server>\epicor\mfgsys803\utilities\BL_tester
> --- In vantage@yahoogroups <mailto:vantage%
40yahoogroups.com> .com, "Daniel
> Laidig" <daniellaidig@>
> wrote:
> > I tried using SearchFunctions.ListLookup
(oTrans, "BomSearchAdapter",
> > recselected, false, whereclause) like I get information for all
the
> other
> > adapters, but the BomSeachAdapter errors out. If I leave all my
> code the
> > same, but change the BomSearchAdapter to PartAdapter, it works
just
> fine.
> > Have you had this problem? I'm using Vantage 8.03.404b. Thanks,
> > Daniel
> > _____
> > From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> [mailto:vantage@yahoogroups <mailto:vantage%
40yahoogroups.com> .com] On
> Behalf Of
> > bw2868bond
> > Sent: Tuesday, July 29, 2008 9:01 AM
> > To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> > BomSearchAdapter ?
> > supply parent, rev, and how you want tree exploded
> > wrote:
> > > I'm looking for a part search adapter that will give me the
> parent
> > part
> > > number and its children. The table in Vantage is PartMtl but I
> > can't find
> > > an adapter to use within my customizations that give me this
> > information.
> > > Does anyone know what adapter I could use? Thanks,
> > > Daniel
> > <http://geo.yahoo <http://geo.yahoo.com/serv?> com/serv?
> s=97359714/grpId=20369/grpspId=1705007181/msgId=6
> > 7391/stime=1217336470/nc1=3848578/nc2=5191952/nc3=3848642>
I'm looking for a part search adapter that will give me the parent part
number and its children. The table in Vantage is PartMtl but I can't find
an adapter to use within my customizations that give me this information.
Daniel
BomSearchAdapter ?
part
can't find
information.
> Daniel
I tried using SearchFunctions.ListLookup(oTrans, "BomSearchAdapter",
recselected, false, whereclause) like I get information for all the other
adapters, but the BomSeachAdapter errors out. If I leave all my code the
same, but change the BomSearchAdapter to PartAdapter, it works just fine.
Daniel
_____
bw2868bond
BomSearchAdapter ?
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Daniel
part
can't find
information.
> Daniel
<http://geo.yahoo.com/serv?s=97359714/grpId=20369/grpspId=1705007181/msgId=6
You will not be able to use the list lookup function for that adapter.
other
code the
fine.
> Daniel
> _____
Behalf Of
> bw2868bond
> BomSearchAdapter ?
parent
> part
> can't find
> information.
> > Daniel
Daniel
_____
bw2868bond
other
code the
fine.
> Daniel
> _____
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf Of
> bw2868bond
> BomSearchAdapter ?
parent
> part
> can't find
> information.
> > Daniel
