Parts in Jobs Blank Title 62810
The only reliable Job detail Mtl tree icon behavior is the checked mark (material fully issued).
The green (ATP OK) and red (ATP not OK) circles haven't worked through 403D.
Suggest you use Action menu Job/Material Status check instead.
The actual tables used by the impenetrable (without the SDK) tree view object are unknown to me. I've always suspected it is doing a Mtl-at-a-time real time (and faulty) ATP check (which potentially explains the sluggish app response time issues I consistently see on jobs with more than 5-10 materials required).
3 tables DO exist that would be a better basis for this: PegDmnMst, PegLink, & PegSuppMst - but they are only as accurate to your last multi-level-pegging process run.
The temp table(s) used by Time Phase Inquiry are generated on the fly by the app and seem to follow the same paradigm as the 3 Peg... tables.
Rob Brown
"Dale R. Kalsow" <dale.r.kalsow@...> wrote:
Good Morning Everyone,
I have a question on jobs and how vantage calculates if it needs to
purchase parts to full fill that job. I know that in the JobMtl table
is all the parts for a job. Does anyone know where Vantage stores the
information on weather or not it has enough parts to be used on the job.
In other words what table changes the icon from a tag with a red circle
to an empty tag?
Thanks!
Dale Kalsow | Information Technologies Director
__________________________________________________________
Determan Brownie, Inc. | 1241 72nd Avenue NE | Minneapolis, MN 55432
* Phone: (763) 502-9689 | * Fax: (763) 571-1789
* dale.r.kalsow@... | * http://determan.com/
"Ambition is the path to success. Persistence is the vehicle you arrive
in."
Electronic Privacy Notice. This e-mail, and any attachments, contains
information that is, or may be, covered by the Electronic Communications
Privacy Act, 18 U.S.C. 2510-2521, and is also confidential and
proprietary in nature. If you are not the intended recipient, please be
advised that you are legally prohibited from retaining, using, copying,
distributing, or otherwise disclosing this information in any manner.
Instead, please reply to the sender that you have received this
communication in error, and then immediately delete it. Thank you in
advance for your cooperation.
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
I know I've done this before but cannot remember how,
Having calculated a value in a Crystal subreport, how can I pass the value
back and make it available to the 'main' form/report?
Hope a Crystal guru out there can help!
Regards,
Richard
Richard Bailey
Dudley Industries
Mailto: rbailey@...
Tel: +44(0)1253 738311
Hi Richard
You need to declare the variable in the sub report as a shared variable.
This makes it available to the main. I don't remember the syntax but
the crystal help should cover it.
Mark D
Of Richard Bailey
Sent: Friday, February 22, 2008 8:06 AM
To: UserGroup
Subject: [Vantage] SubReport Calculated Value
value
Regards,
Richard
Richard Bailey
Dudley Industries
Mailto: rbailey@...
<mailto:rbailey%40dudleyindustries.co.uk>
Insert --> subreport....is this what you were looking for?
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Richard Bailey
Sent: Friday, February 22, 2008 7:06 AM
To: UserGroup
value
Regards,
Richard
Richard Bailey
Dudley Industries
Mailto: rbailey@...
This should help
http://diamond.businessobjects.com/node/251
Kersten MacLennan
IT/ERP Analyst
Semrock, Inc.
3625 Buffalo Rd.,
Suite 6
Rochester, NY 14624
585-594-7009
585-594-7095 fax
kmaclennan@...
The Standard in Optical Filters for Biotech & Analytical Instrumentation
Hundreds of Thousands of Ion Beam Sputtered filters delivered -
extensive inventory now!
The information contained in this message and any attachments may be
privileged, confidential, and protected from disclosure. If the reader
of this message is not the intended recipient, or any agent responsible
for delivering this message to the intended recipient, you are hereby
notified that any dissemination, distribution, or copying of this
communication may be unlawful and therefore strictly prohibited. If you
received this message in error, please reply to the message and delete
it. Thank you
Of Richard Bailey
To: UserGroup
value
Regards,
Richard
Richard Bailey
Dudley Industries
Mailto: rbailey@...
Also don't forget that any variable that you want to pass between the subreport and main report has to be declared (in both reports) as a Shared variable.
Ahmet Erispaha
aerispaha@...
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Richard Bailey
To: UserGroup
value
Regards,
Richard
Richard Bailey
Dudley Industries
Mailto: rbailey@...
to an empty tag?
Thanks!
____________________________________________________________________
in."
