Hello!
I’m wanting to take a beautiful synchronous process that creates customer shipments and turn it into an async process so the user does not have to wait for shipments to be made.
It all works great in sync, and in async I do synchronously grab the user id and plant before using the Customer Shipment BO async.
The required and very helpful method:
GetOrderRelInfo works synchronous but in async it keeps trying to use the plant the task agent service is in. I set the plant before calling this method. Is there a way to make this method aware of the desired (target) plant, or will I need to populate columns a different way? (yuck)
Action<int, int, int, int> createShipDtl = (myHeaderNum, myOrderNum, myOrderLine, myOrderRel) =>
//Check to ensure we will never add a duplicate line to the pack
if (!Db.ShipDtl.Where(w => w.PackNum == myHeaderNum && w.OrderLine == myOrderLine && w.OrderRelNum == myOrderRel).Any())
SentrySdk.AddBreadcrumb(
message: "Order: " + myOrderNum + " Line: " + myOrderLine + " Release: " + myOrderRel,
level: BreadcrumbLevel.Info);
using (var customerShipSvc = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.CustShipSvcContract>(Db)) //Create Customer Shipment BO
//We can only send in 1 dtl line per update or else the method is gunna have a bad time
myCustShipDataSet.ShipDtl.Clear();
//Create a new dtl row with defaults
customerShipSvc.GetNewOrdrShipDtl(ref myCustShipDataSet, myHeaderNum, myOrderNum);
//Select the current pack detail row
var currPackLine = myCustShipDataSet.ShipDtl.Where(w => w.PackLine == 0).FirstOrDefault();
currPackLine.OrderNum = myOrderNum;
currPackLine.OrderLine = myOrderLine;
currPackLine.Plant = syncPlant;
//Check part on the line
customerShipSvc.CheckPrePartInfo(ref prePartPartNum, currPackLine.OrderNum, currPackLine.OrderLine, out prePartvMsgText, out prePartVSubAvail, out prePartvMsgType, out prePartOrigPartNum);
//Get order line details and populate shipdtl row
customerShipSvc.GetOrderLineInfo(ref myCustShipDataSet, currPackLine.PackLine, currPackLine.OrderLine, prePartOrigPartNum);
//Set row order release num
currPackLine.OrderRelNum = myOrderRel; //for async
customerShipSvc.GetOrderRelInfo(ref myCustShipDataSet,0, myOrderRel, true);
//Set the partNum on the line. Need to do this as there is a bug here
currPackLine.PartNum = prePartOrigPartNum;
//Get part details of the order line and populate shipdtl row. Need to call because of bug
customerShipSvc.GetPartInfo(ref myCustShipDataSet, currPackLine.PackLine, ref prePartOrigPartNum, Guid.Empty, string.Empty, out getPartInfo, out getPartInfo, out getPartInfoB, out getPartInfo);
//Set Shipped Quantity to 0 as it defaults to release quantity
customerShipSvc.GetQtyInfo(ref myCustShipDataSet, currPackLine.PackLine, 0, 0);
//Finally update the record with our data
customerShipSvc.UpdateMaster(ref myCustShipDataSet, false, false, false, false, false, false, false, myHeaderNum, 0, out opReleaseMessage, out opCompleteMessage, out opShippingMessage, out opLotMessage, out opInventoryMessage, out opLockQtyMessage, out opAllocationMessage, out opPartListNeedsAttr, out opLotListNeedsAttr, out shipCreditMsg, out cError, out compError, out msg, out opPostUpdMessage, out updateComplete, out checkComplianceError, out changeStatusError, out checkShipDtlAgain);
