# Passing Parameters to Bartender from Screen **Category:** [Epicor ERP 10](https://www.epiusers.help/c/e10/5) **Created:** 2017-02-09 20:59 UTC **Views:** 1537 **Replies:** 2 **URL:** https://www.epiusers.help/t/passing-parameters-to-bartender-from-screen/37231 --- ## Post #1 by @EpiUser Hello, I'm trying to make a button inside shipment entry that prints a bartender label. I need to pass parameters to the report from the shipment entry screen. I'm familiar with this code to open a report using the Process.Start(bartender.exe location, report path) Report path part looks kind of like this: /F=c:\Formats\ship.btw /P That is basically the path to the report So for things like SSRS I would put the parameters in that string with something like: /F=c:\Formats\ship.btw/?PackNum="12345"/?PackLine="1"/P This would be for parameters named PackNum and Pack Line. However when I try this method I get an error or it opens up the report with the parameters blank. Also I get error messages related to some characters like "\" and "/" which are our in our customer part number field I'm trying to pass as a parameter value.It says it doesn't recognize the parameter /54-8 but that is just the last part of a Xpart number like 08MOUNT7/54/-8 I'm trying to pass. Any information would be appreciated. Thanks --- ## Post #2 by @josecgomez Try using bartender commander and a command file instead. Basically setup bartender commander to monitor a folder (Folder X) and drop a file from Epicor into that folder in the right format of Bartender (Examples available all over the place) which basically have the name of the label, as well as the data that you want to drive from the label --- ## Post #3 by @Chris_Conn I gave up trying to pass parameters to bartender report style and wrote my own bartender file generator --- **Canonical:** https://www.epiusers.help/t/passing-parameters-to-bartender-from-screen/37231 **Original content:** https://www.epiusers.help/t/passing-parameters-to-bartender-from-screen/37231
