Past due report in vantage 8.03.408B
Thanks, I will see if I can do that...
----- Original Message -----
Date: Saturday, May 14, 2011 20:02
Subject: RE: [Vantage] Past due report in vantage 8.03.408B
> James,
> If you open up the Crystal report, go to that field, right click
> and format
> field, then go to the font tab. On the right, you'll see
> icons next to the
> font, the style, the size, and the color. These are your
> conditionalformatting buttons. For example, if you click
> on the one next to the color,
> you can conditionally set the color. It will come up with
> the various
> values commented out. What you can do in the code
> then is have a statement
> like this:
> If <fieldname> < CurrentDate then crRed
> Else crBlack
> You could get as fancy as you want - different size fonts,
> borders around
> the fields, etc.
> Just one note - if you're doing this to a standard form, make
> sure to copy
> that report to the CustomReports subfolder, and make your
> changes to a copy.
> When you do an upgrade, anything in the base reports folder can get
> overwritten, but your custom reports will not. Then,
> you'll have to set up
> a new report style and point it to your custom report.
> Kevin Simon
> SimsTrak Consulting
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]
> On Behalf Of
> danielj56
> Sent: Saturday, May 14, 2011 4:45 PM
> Subject: [Vantage] Past due report in vantage 8.03.408B
> New to Vantage ERP....
> Currently there is a past due report in Vantage which our
> Customer service
> person uses and she has asked me if there is a way to highlight
> the lines on
> the report if the day is less than today. I know that she can
> put in a date
> range to just give her anything before today. She just wants to
> dump it all
> out and see it highlighted.
> I have 2 other questions but will put them in separately..
> Thanks,
> James
Currently there is a past due report in Vantage which our Customer service person uses and she has asked me if there is a way to highlight the lines on the report if the day is less than today. I know that she can put in a date range to just give her anything before today. She just wants to dump it all out and see it highlighted.
James
James,
If you open up the Crystal report, go to that field, right click and format
field, then go to the font tab. On the right, you'll see icons next to the
font, the style, the size, and the color. These are your conditional
formatting buttons. For example, if you click on the one next to the color,
you can conditionally set the color. It will come up with the various
values commented out. What you can do in the code then is have a statement
like this:
Else crBlack
You could get as fancy as you want - different size fonts, borders around
the fields, etc.
Just one note - if you're doing this to a standard form, make sure to copy
that report to the CustomReports subfolder, and make your changes to a copy.
overwritten, but your custom reports will not. Then, you'll have to set up
Kevin Simon
SimsTrak Consulting
danielj56
James
