Thanks Mark for the heads up.
Barbara
----- Original Message ----
Sent: Wednesday, June 4, 2008 1:36:36 PM
Subject: RE: [Vantage] Patch Upgrade
minutes. The "verify that it is working" depends on how well you check. If
it's a real concern, I'd try it on a test server first.
Check your invoices, especially those with misc. charges. We found a change
to the Report Data Definition that whacks it out. I think 305K changed that.
Just re-implement any Crystal changes from the newest version and you should
be good to go.
Mark W.
Barbara
> I need to install Pat 8.03.305L (we are currently on 8.03.305F). After weThe actual patch process is quite fast. On our machine, it's just a few
> backup the database, how long will it take to install the patch and verify
> that it is working?
be good to go.
Mark W.
