Payroll Module Setup
Jerry-
I called Sandy Morse directly and discussed. Seems the "LABOR TO
PAYROLL" checkbox "unchecked itself" (I probably didn't click all the
"OK" buttons after checking it the first time). Problem solved. Thanks
to you and Sandy for your assistance!
Thanks!
Rick Ludwig
Sent: Tuesday, March 08, 2005 3:32 PM
Subject: RE: [Vantage] Payroll Module Setup
I wouldn't think a restart would be needed either. Have you "activated"
your payroll with a beginning date? (carefully - this can not be changed
later)
Sent: Tuesday, March 08, 2005 3:13 PM
Jerry-
It is not automatically checking the "PAYROLL" box (the clerk even
logged
out/back in). Do I maybe need to re-start Vantage on the server
- I wouldn't think so.
Thanks!
Rick Ludwig
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129pub37r/M=298184.6018725.7038619.3001176/
D=groups/S=1705007183:HM/EXP=1110444410/A=2593423/R=0/SIG=11el9gslf/*htt
p://www.netflix.com/Default?mqso=60190075> click here
<http://us.adserver.yahoo.com/l?M=298184.6018725.7038619.3001176/D=group
s/S=:HM/A=2593423/rand=679746372>
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
To those who have set up the Payroll Module...
I've asked similar payroll setup question in the past and I thought I
had all of my "ducks in a row" for testing; however, I think I found
something that will not permit me to do this the way I had intended.
My plan was to make a current copy of our DB and go back to the 4th
quarter of 2004 and enter YTD payroll information into the DB copy and
key in the weekly payrolls of October/November/December using the labor
hours already input via Labor Entry to gain a comfort level that
everything is setup correctly and to "work out the bugs". However, I
believe since we are interfaced and once I run the WIP/Capture Post
routine at the end of every month, I can not go back and check the
"Payroll" box on each employee's daily labor hours input (Labor Entry)
in order to "Feed Payroll". Is this correct? In addition and if this
is correct, how do I get this box to be checked automatically going
forward - enter a beginning payroll date in the Payroll Module
configuration? Currently, it is not checked during the daily labor
entry process, and I've got to believe there is a way to have this box
automatically checked.
My plan "B" would be to enter a date (I assume as of 3/7/05) and make
another DB copy at the end of March so that I can use March as my "test
month". In addition, I would also run parallel on the live DB for the
months of April/May/June before going live on 7/7/05.
Any thoughts or ideas would be appreciated!
Sincerely,
Rick Ludwig, C.P.A.
Vice President of Finance & Administration
Metal Spinners, Inc.
Angola, IN 46703
DIRECT (260) 665-2158 x25
FAX (260) 665-9452
In company configuration, data collection module there is a "labor to
payroll" checkbox. If checked your labor hours will automatically be
checked for "payroll". After you have run the capture you can not edit the
labor entries in any way.
Jerry Boyle, Controller
Sipco Molding Technologies
Meadville, PA. 16335
p 814.724.2243 x53
f 814.724.2244
vantage 6.10
Sent: Tuesday, March 08, 2005 8:33 AM
To: Vantage@yahoogroups.com
Subject: [Vantage] Payroll Module Setup
I've asked similar payroll setup question in the past and I thought I had
all of my "ducks in a row" for testing; however, I think I found something
My plan was to make a current copy of our DB and go back to the 4th quarter
of 2004 and enter YTD payroll information into the DB copy and key in the
weekly payrolls of October/November/December using the labor hours already
input via Labor Entry to gain a comfort level that everything is setup
correctly and to "work out the bugs". However, I believe since we are
interfaced and once I run the WIP/Capture Post routine at the end of every
month, I can not go back and check the "Payroll" box on each employee's
daily labor hours input (Labor Entry) in order to "Feed Payroll". Is this
correct? In addition and if this is correct, how do I get this box to be
checked automatically going forward - enter a beginning payroll date in the
Payroll Module configuration? Currently, it is not checked during the daily
labor entry process, and I've got to believe there is a way to have this box
Jerry-
We do not use the Data Collection Module (we have a clerk manually enter
timecards via Labor Entry). Given this, I wonder if your suggestion is
valid for us? (the Data Collection button on the Configuration screen is
grayed out).
Thanks!
Rick Ludwig
Sent: Tuesday, March 08, 2005 8:48 AM
the
p 814.724.2243 x53
f 814.724.2244
vantage 6.10
had
something
quarter
the
already
every
this
be
the
daily
box
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129rr76o3/M=298184.6018725.7038619.3001176/
D=groups/S=1705007183:HM/EXP=1110376303/A=2593423/R=0/SIG=11el9gslf/*htt
s/S=:HM/A=2593423/rand=773514132>
_____
Yahoo! Groups Links
You would have to check the "payroll" box for each time entry. Even in our
setup if we manually add time for an employee the box is not checked by
default. I do not know of any way to change that default. If anyone does I
would like to know also. We have to occasionally add time for an employee
and we must remember to check it or I get a visit on pay day.
p 814.724.2243 x53
f 814.724.2244
vantage 6.10
Sent: Tuesday, March 08, 2005 10:01 AM
Jerry-
grayed out).
I believe if you check the "Labor to Payroll" box in Data Collection
Configuration in Module Configuration, the "Payroll" box will be checked
when you manually add time. Ours does.
Randall Lunsford
Excel Machinery, Ltd.
e-mail: rlunsf@...
Phone: (806) 335-4565 ext. 531
Fax: (806) 335-9017
Sent: Tuesday, March 08, 2005 9:35 AM
our
does I
employee
p 814.724.2243 x53
f 814.724.2244
vantage 6.10
Jerry-
grayed out).
Yahoo! Groups Links
Jerry-
You're kidding!! I find it hard to believe that Epicor wouldn't have a
way to automatically "check the box" if you are running Vantage Payroll
and that other Vantage Payroll users haven't complained about this one.
Seems like an easy fix! I will inform our data entry clerk that she
must begin to check this box as she enters labor. No doubt, this will
occasionally be missed.
Any other Payroll users agree?
Thanks!
Rick Ludwig
Sent: Tuesday, March 08, 2005 10:35 AM
our
does I
employee
p 814.724.2243 x53
f 814.724.2244
vantage 6.10
Jerry-
grayed out).
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129p7j4bv/M=298184.6018725.7038619.3001176/
D=groups/S=1705007183:HM/EXP=1110382577/A=2593423/R=0/SIG=11el9gslf/*htt
s/S=:HM/A=2593423/rand=427379252>
_____
Yahoo! Groups Links
That is interesting because we use data collection and the "Labor to
Payroll" has always been checked. When we add time manually through labor
entry the "payroll" checkbox does not default to checked. It is checked if
we go in to edit any time entered through data collection but we have to
remember to check it for manual entries. There must be another
configuration somewhere that I haven't found. I will do some looking now
that I know it is possible.
Thanks Randy.
Sent: Tuesday, March 08, 2005 10:44 AM
Randall Lunsford
e-mail: rlunsf@...
Fax: (806) 335-9017
our
does I
employee
p 814.724.2243 x53
f 814.724.2244
vantage 6.10
Sorry, I just spoke with our person who works with our labor edits and it
does default to checked for manual entries. I was thinking about our
smaller company that does not use the "Labor to Payroll" function.
Rick, if you have the Job management module the "Labor to Payroll" checkbox
is also shown in JM configuration. Maybe it is available to you there?
p 814.724.2243 x53
f 814.724.2244
vantage 6.10
Sent: Tuesday, March 08, 2005 10:46 AM
Jerry-
You're kidding!! I find it hard to believe that Epicor wouldn't have a way
to automatically "check the box" if you are running Vantage Payroll and that
Seems like an easy fix! I will inform our data entry clerk that she must
Jerry-
Yes, I found that box on the JM Module Configuration!
I have checked it and will see wait and see if it works once today's 1st
shift labor cards are entered later today.
Thanks!
Rick Ludwig
Sent: Tuesday, March 08, 2005 11:09 AM
it
checkbox
p 814.724.2243 x53
f 814.724.2244
vantage 6.10
Jerry-
way
that
must
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129n4c960/M=298184.6018725.7038619.3001176/
D=groups/S=1705007183:HM/EXP=1110392236/A=2593423/R=0/SIG=11el9gslf/*htt
s/S=:HM/A=2593423/rand=763077828>
_____
Yahoo! Groups Links
Jerry-
logged out/back in). Do I maybe need to re-start Vantage on the server
Thanks!
Rick Ludwig
Sent: Tuesday, March 08, 2005 2:23 PM
Jerry-
Thanks!
Rick Ludwig
it
checkbox
p 814.724.2243 x53
f 814.724.2244
vantage 6.10
Jerry-
way
that
must
ADVERTISEMENT
_____
Yahoo! Groups Links
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=1295k29ti/M=298184.6018725.7038619.3001176/
D=groups/S=1705007183:HM/EXP=1110396373/A=2593423/R=0/SIG=11el9gslf/*htt
s/S=:HM/A=2593423/rand=361473197>
_____
Yahoo! Groups Links
Rick,
On our test database I unclicked the "Labor to Payroll" box, went to
Labor Entry and the Payroll box was unchecked. Then I went back and
clicked "Labor to Payroll", went back into Labor Entry and the Payroll
box was checked. I am not sure what is happening with yours but that IS
the checkbox that controls whether the labor detail is sent to payroll.
Sandy Morse
BVR Technologies Company
815-874-2471 x112
later)
Jerry-
It is not automatically checking the "PAYROLL" box (the clerk even logged
Thanks!
Rick Ludwig
