# (PAYROLL) Printing the payroll check register in 3.0 **Category:** [Yahoo Archive](https://www.epiusers.help/c/yahoo-archive/9) **Created:** 2000-08-14 14:30 UTC **Views:** 461 **Replies:** 2 **URL:** https://www.epiusers.help/t/payroll-printing-the-payroll-check-register-in-3-0/773 --- ## Post #1 by @system
Thanks Dina:
We are not yet running data collection, so we are feeding payroll from the
Labor Entry module.
Sent: Monday, August 14, 2000 2:22 PM
To: vantage@egroups.com
Subject: Re: [Vantage] (PAYROLL) Printing the payroll check register in
3.0
Dan,
Are you just starting payroll with Vantage? If so have you checked the box
to "Feed to Payroll" under company configuration (under Data Collection)?
I believe not having this correct will give you this error.
Have a good day :)
Dina
Dan Nichols wrote:
> I am in 3.0 and tried to print the payroll check register. We are
currently
> processing payroll in Vantage to include cutting checks. It does not
matter
> what period I try to print, it tells there are no payroll records
available
> for processing.
> Any ideas?
> Daniel A. Nichols
> General Manager
> If any part of this message is unreadable, please contact the above at
> dann@...
--- ## Post #2 by @system
Dan,
Are you just starting payroll with Vantage? If so have you checked the box to "Feed to Payroll" under company configuration (under Data Collection)? I believe not having this correct will give you this error.
Have a good day :)
Dina
Dan Nichols wrote:
> I am in 3.0 and tried to print the payroll check register. We are currently
> processing payroll in Vantage to include cutting checks. It does not matter
> what period I try to print, it tells there are no payroll records available
> for processing.
> Any ideas?
> Daniel A. Nichols
> General Manager
> dann@...
--- ## Post #3 by @system
P.S. If this is your problem - I believe for the this group you will manually need to change this optionl. Job Management - Labor Entry - Choose Employee - Update Time - Check box for payroll.
Dina
> for processing.
> Any ideas?
> Daniel A. Nichols
> General Manager
> dann@...
--- **Canonical:** https://www.epiusers.help/t/payroll-printing-the-payroll-check-register-in-3-0/773 **Original content:** https://www.epiusers.help/t/payroll-printing-the-payroll-check-register-in-3-0/773
