# Payroll Reporting **Category:** [Yahoo Archive](https://www.epiusers.help/c/yahoo-archive/9) **Created:** 2000-08-10 16:41 UTC **Views:** 384 **Replies:** 2 **URL:** https://www.epiusers.help/t/payroll-reporting/740 --- ## Post #1 by @system
Or, you could contact the following for a very cheap fix so you can use
Report Builder with Payroll. (Works GREAT)
Advanced Research
419-842-1144
www.advancer.com <http://www.advancer.com>
info@... <mailto:info@...>
You can also use this "cheap fix" with ODBC to use for writing crystal
reports. I also use this for automating our 401k, direct deposits and
Flexible spending. I don't know what I did before I got this.
--- ## Post #2 by @system
Sonya,
You could use Results, but that's the hard way.
You can use the Export utility and put it into any format you want. Export
takes care of the encryption.
Advanced Research
419-842-1144
Dave Cole
Reeder & Kline
Sent: Thursday, August 10, 2000 1:15 PM
To: One List (E-mail)
Subject: [Vantage] Payroll Reporting
I need to right a report showing each of our employees and their Y-T-D
net earnings. Does anyone have a report like this?
If not, then how do I write the report when the info. I need is
encrypted?
Sonya L. Coyle
Administrative Assistant
HDJ Company, Inc.
_____
<http://click.egroups.com/1/7747/13/_/411782/_/965934265/>
<http://adimg.egroups.com/img/7747/13/_/411782/_/965934265/yellowaria_new1.g
if>
_____
<http://www.egroups.com/files/vantage/>
--- ## Post #3 by @system
Have you looked at the Earnings Report under Payroll/Reports?
encrypted?
Sonya L. Coyle
HDJ Company, Inc.
--- **Canonical:** https://www.epiusers.help/t/payroll-reporting/740 **Original content:** https://www.epiusers.help/t/payroll-reporting/740
