PayrollDate field in Laborhed
I'm not sure of the exact rules but anecdotally, it worked perfectly
as expected for us when we were operating 24 hours with 3 shifts. The
PayrollDate for our third shift beginning at 11pm would be rolled
forward to the next day as expected.
The biggest problem in V6 and in V8.00 (not sure if it's been fixed in
later versions) are the Labor Edit and Production Detail reports are
NOT adjusted for PayrollDate but instead use ClockInDate. Not good!
I have had to rewrite both of these reports. It's a real shame but
Epicor forces you to have a good reporting person on staff or spend
big bucks on consultants to customize what should be basic data data
requirements.
--- In vantage@yahoogroups.com, Tony Hughes <thughes281@...> wrote:
> The data dictionary has this to say about the PayrollDate field in
Laborhed:
> "The Payroll date is the "Logical Day" that labor occurred. In
mostcases this is the same as the "Physical Day". But when work is
donebefore and after midnight then "Labor Collection" rolls the
physicaldate forward or backward to create a Logical date"
> My question is, if you don't have Payroll module, what is
thedefinition of whether the Payroll date is rolled forward or
backward? Ilooked at the laborhed entries, and I have an idea, but I
don't want tomake an assumption. Is it configured somewhere or just
follows astandard rule?
> Thank you.
____________________________________________________________________________________
> You rock. That's why Blockbuster's offering you one month of
Blockbuster Total Access, No Cost.
> http://tc.deals.yahoo.com/tc/blockbuster/text5.com
The data dictionary has this to say about the PayrollDate field in Laborhed:
"The Payroll date is the "Logical Day" that labor occurred. In mostcases this is the same as the "Physical Day". But when work is donebefore and after midnight then "Labor Collection" rolls the physicaldate forward or backward to create a Logical date"
My question is, if you don't have Payroll module, what is thedefinition of whether the Payroll date is rolled forward or backward? Ilooked at the laborhed entries, and I have an idea, but I don't want tomake an assumption. Is it configured somewhere or just follows astandard rule?
Thank you.
You rock. That's why Blockbuster's offering you one month of Blockbuster Total Access, No Cost.
