PCID Generator and BarTender Label error
Hi
Did someone was able to print a label from PCID Generator from Bartender 2016
Every time a get a message from the Integration Builder
‘Unable to run action Print Command Script because the script is empty.’
But Epicor 10.2.300 and 10.2.400 output a .bt file with a command script on it
%BTW% /AF=“Reports\PCIDLabel.btw” /D="" /PRN="\ecs-fileserv\Xerox versalink C7030" /DBTEXTHEADER=3 /R=3 /P
%END%
i tried different things
read the .bt file and command script input data
rename extension to a .txt file and change the input data to Text Tab Delimited
always the same message
thank for your help
Philippe
I got the answer.
Integration Builder
n the Print Command Script
Variable, user the EventData variable and not a user variable
