PE Log Viewer - Error
Hi All,
Any one seen this? I thought it was due to the fact that AR Clearing was switched on in Company Config but in our Test DB we don’t have it own. (Clone from Live)
Error:
[Warning!] Unable to extract segment SegValue2 value
Company Config
Any ideas?
Aaron.
Hi Aaron, I did some research on this a couple of years ago and if I remember correctly it is just a warning and the posting should still go through. Check the Book Maintenance>Posting>Validations tab. Should shed some light on what you have set up in your book.
Hope this helped.
We had a credit memo go to the RJ with a similar error. Turns out a part didn’t have the GL set correctly. Shot in the dark…
What is your SegValue2? For us it’s what Epicor calls “Division.” Is it that, or your Department/Sales Category?
Because that thing always tries to plug in the division and we just don’t have a division GL set up on some of the sites, and that’s OK. I’ve learned to ignore the warnings.
No kidding. Learned something new there.
