Hi All,
Is it possible to open a PE Log File offline?
I have a 2.1 GB and it just freezes epicor.
Aaron
Hi All,
Aaron
If you are logging your inventory wip recon report - it will be large.
If you can open the file in the view - copy it out to excel. I have found the excel an easy way to color code and search through the text.
It retains the indents when it pasted into excel too.
If you are running inventory wip to make the file smaller filter it with transaction types and date ranges.
Try using the 64 bit version of the Client - Epicor64.exe - to open the Log.
