Quoting from the Sysadmin Reference Manual -spin entry:
" On mutli-processor machines, try a value of 2,000. If this causes too much CPU usage, reduce the value. If you have many fast processors, a value as high as 10,000 might be effective".
There is also a note on how to evaluate -spin values using promon (to long to quote here).
HTH.
"Winter, Patrick" wrote:
William E. Colls Tel 613 591 0079
PROComputer Systems Fax 613 591 3924
67 Willow Glen Dr www.procomsys.com
Kanata Ontario Canada PEG Member 1998051404
Specialists in Progress Software development since 1985
HTH.
> I'm not sure where 2 came from, the processors are 550mhz, I'm having Jay--
> Erickson look at my database log file for other improvements, thanks for
> pointing this out.
> Patrick J. Winter
> Information Services Manager
> sSc Specialty Screw Corporation
> Vantage 4.00.901
> -----Original Message-----
> From: William Colls [mailto:william@...]
> Sent: Tuesday, November 21, 2000 10:35 AM
> To: vantage@egroups.com
> Subject: Re: [Vantage] Performance Tuning Story to Share
> How did you arrive at a value of 2 for the -spin parameter? How fast are
> your processors?
> We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
